Old 05-15-2005, 11:14 PM
SidewayzS15's Avatar
SidewayzS15 SidewayzS15 is offline
Send a message via AIM to SidewayzS15
Tutorial: Making Exhausts
Step 1: Get materials, you will need 2 pipes (one that will fit in the other one), a dremel, silver paint (silver sharpie also works), paint pen, a file, sandpaper, a x-acto knife, glue, tape, index card, and putty. here are some pics of wut you will need.
http://img238.exs.cx/img238/8606/materials0qf.jpg
Step 2: cut the pipes like so
http://img238.exs.cx/img238/3461/pipescut7ml.jpg
Step 3: when you put the pipes together you will see there is a little gap... we can fix this with a cut peice of index card. after you cut the index card you put it around the silver pipe and insert the silver
pipe with the index card on it into the barss pipe.
http://img238.exs.cx/img238/1447/gap9fv.jpg
http://img238.exs.cx/img238/4488/pipesfitted1fx.jpg
Step 4: apply glue around the silver pipe to hold the index card and the pipe in the brass pipe. You might also want to use a lil krazy glue. DONT USE TOO MUCH GLUE.a little glue will go a long way. the glue is the lil ring that looks like weld...
http://img238.exs.cx/img238/228/pipesglued3tg.jpg
Step 5: now is when you will use your glazing putty. apply putty on top of the glue joint that you have just made.
http://img102.exs.cx/img102/6357/puttied9iv.jpg
Step 6: Now you must wait for the putty to dry. i would give it a good 20 minutes. while you are waiting you can get your sand paper out.
Step 7: After the putty has dried sand smooth like so, also if you want you can cut the pipe on a slant like i have done.
http://img102.exs.cx/img102/2199/pipessanded4iz.jpg
http://img102.exs.cx/img102/62/pipessandedside2hz.jpg
Step 8: Now that you hopefully sanded everything down with no problems, paint the brass pipe, i painted mine black for a C/F look.
http://img102.exs.cx/img102/5761/drying2pi.jpg
Step 8: Make sure the black is dry, now you can do the silver area i used the sharpie becasue it was easier, and it fit nicely in there, but you can also use silver paint. here is the final product.
http://img102.exs.cx/img102/9865/silver18kk.jpg
http://img102.exs.cx/img102/8897/silver24jb.jpg
Lemme know what you guys think, i think it came out very nicely am going to use this on my next import i build.
Thanks to ImageShack for Free Image Hosting
Old 05-16-2005, 05:35 AM
flyonthewall's Avatar
Car Mod guy
So, does anyone else want to make an exhaust how to?
How many do we have now?
Old 05-16-2005, 06:40 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Tutorial: Making Exhausts
Oh, allright, fine. I'll do an exhaust tutorial. Soon as I start my next build....
PHOTOBUCKET SUCKS
Old 05-16-2005, 10:03 AM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Yes, but they're all different methods. I think they all have their pro's and cons. Though I think mine is the best :P
In the end, the exhaust is one of the most important things on show cars we like to build.
