Go Back   Automotive Forums Car Chat > Ford > Probe
Old 05-15-2005, 11:24 PM
Sintek Sintek is offline
KLZE with mods 178 hps at wheels?
would this be right.. or should there be more HP..? to the wheels ?
copy and pasted from automart.ca
Klze engine with: headers exhaust 3" cat, flywheel, stage 2 clutch, intake, big fuel pump, fuel pressure regulator, port polish, kyb shocks, crank pulley, ecu reprogrammed for j-spec 178 hp at the wells 1/4 mile in 14.50 sec. 160,000 km
Old 05-25-2005, 04:05 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: KLZE with mods 178 hps at wheels?
with all that u would think it would be more like 200whp the engine and ecu alone is 200 hp at the flywheel
Old 06-02-2005, 12:38 AM
blindfoldedhope blindfoldedhope is offline
Send a message via AIM to blindfoldedhope
sounds almost right maybe a little higher at about 190 or so depending on the condition of the engine.... and what flywheel... mx-3 15lb or findiza 9lb i just put a mx-3 on my car and it revs nice and fast... sweet wheel for a $40 upgrade compaired to the $300-$400 9lb
Old 06-02-2005, 01:19 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
sounds right since the klze is 141 at the wheels. With all those mods gotta put it up there especially since they have high compression and fixing the air can make huge changes on probes
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
