Go Back   Automotive Forums Car Chat > Volkswagen > Rabbit
Old 05-15-2005, 11:15 PM
davvpar davvpar is offline
Send a message via MSN to davvpar Send a message via Yahoo to davvpar
Vacuum
Hello, i have a 1.8 VW GTI from 84 and i need to know where all the vacuum lines go because my diagram is off the hood and i have several broken vacuum lines, but mostly the brown one that goes towards the cold start valve i have no idea where it goes and i need some help.
Also i have two other problems, my intake air bypass valve or the ground white cylinder mount on the passenger side strut tower, my valve is always hot, even though the car is off, it stalls hot until i unplug it, so what should i check to fix this. And my other problem is that when i stick in a 30Amp fuse into the radiator fan slot on the fuse block the fan stays on, even after i unplug the switch. This car has lots of electrical problems and i need help.
I love anything with an engine, as long as, it's not a ford.
Old 05-21-2005, 12:01 PM
grandmastergd grandmastergd is offline
Re: Vacuum
Dude I think that I'm going to need more info, but I'll tell you Rabbits suffer from a little problem called rust! I will say that the windshield frame has a problem with rust and you are getting a little water leak from that. The water runs down the bottom of the drip panel and drips right on top of the fuse panel. There are at least 3 curcuit boards inside the fuse panel and your problem is probably inside the panel. I have had problems like this at the shop for years with the rabbits. I will tell you this though, I don't guess, and I feel that if you are not confident with the wiring you might want to take it to a VW specialist. Most techs can diagnose a problem like you have in .5 of an hour so it shouldn't cost that much.(for the info)
Old 05-28-2005, 08:42 AM
termitesgraffix's Avatar
termitesgraffix termitesgraffix is offline
Send a message via AIM to termitesgraffix
email me a pic of under the hood and a few closeups... i will draw lines for ya...
