Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-15-2005, 01:47 PM
swift1069 swift1069 is offline
Send a message via AIM to swift1069 Send a message via Yahoo to swift1069
heating problem again!!!!!
I replaced everything on the car to do with the cooling system. I know I have a minor leak,and when the car loses about 2 cups of water it wants to start to over heat. But if I open up my heater core valve and allow water to flow then the car wont over heat, even when it gets lower on water.. I'm thinking there is a blockage somewhere but I've watched it with the radiator cap off and the water seems to be circulating fine.. I thought it could be my sterio system too, because when the bass hits hard at a idle the motor will stumble a bit, but I turned the sterio off for a few days and noticed it does the same thing... If anyone has any thoughts let me know.... Could it be a weak water pump and not circulating the water fast enough???
Old 05-15-2005, 04:16 PM
BullShifter's Avatar
Re: heating problem again!!!!!
Where is it leaking from? It's over heats when low because of an air pocket. If you replaced every thing how could it be leaking?
Old 05-15-2005, 05:28 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
leaking will cause a loss in pressure, whihc is probably causing your overheating
Team Lonely Drivers
Old 05-15-2005, 07:05 PM
Re: Re: heating problem again!!!!!
well the only thing that hasn't been change is the o rings on the water line that runs from the themostat housing to the back of the water pump... that and the head gasket but I'm leaning more to a leaking head gasket for a water leak because there is always a bit oil on top of the tranny. At first I thought it was all coming from the seal in the distributor because I started to notice a bit of oil on the inside of the distributor cap... ... I have good even compression in all 4 cylinders.but probably just a matter of time before it starts to leak into the cylinder
