1988 no spark
Have an '88 with 1.9L, while driving about 45mph, she just died cold. Hasn't run since. Getting fuel fine. Throttle body type fuel injection. Found a no spark condition. No spark even from coil to dist cap. All other electrical stuff works fine, (starter, fuel pump, dash lights with key on, etc.) I'm no electronics expert, but my brother and I went through the testing procedures in the manual and the coil seemed to check out ok. We pulled the dist. and did the tests on the ignition module, and that also seemed ok. Started doing the wiring harness to distributor tests and found the testing of the #2 terminal only had 4.4 volts where it should have had battery voltage. The other two wires tested produced battery voltage. We tried cutting that wire and applying a straight 12 volts from the battery but that didn't do it either, still no spark. We had left the other end of the wire we had cut 'open' (in other words, we didn't TEE in 12 volts. Don't know if this was the correct way to do it or not. Book says that it's possible that this lower voltage on one wire to the dist. could be caused by a faulty ignition switch, so was trying to figure out how to bypass the ignition switch. That's why I ran the 12v to that wire going to the dist. Any help would be appreciated. Thanks in advance.
Re: 1988 no spark
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks |
Re: 1988 no spark
Thanks for the replies, folks.
Timing belt wouldn't cause a no spark, would it? I will check on the wiring links also. Have been away from the computer for a while and won't be able to get back on for awhile. Thanks again. Kid |
Re: Re: 1988 no spark
Rotor DOES turn while cranking the motor.
I am away from the car now, but will let my brother know about these posts to help us find the problem. Thanks, Kid |
Re: 1988 no spark
I had the same problem years ago with my 88 EXP
ended up losing the fuel pump too I replaced everything as far as the ignition system i began looking at the computer could not afford a new one and the junk yard did not have the correct one, sorry to say i never got to drive it again Check The Computer it is not easy to get out but it can be done Good Luck!!
Re: 1988 no spark
thanks 88Regal
Hope we have better luck than you did Kid |
Hey Lawton_kid,
did you ever solve the problem with your escort because my car has almost the identical problem , if you did can you please reply and give me some help in repairing my 88 escort. Thanks |
Re: 1988 no spark
Sorry Ehrlich,
my brother hasn't checked into it any farther and she's still sittin'. I haven't been back there to help him with it either. He is 600 miles away, so...... Kid |
A buddy of mine had an '88 and the ignition switch went bad. He had to wiggle the keys around to get it to keep running. He had more keys than a jailer so I think all the extra weight wore something out. If you have 12 volts going to the coil then this would NOT be the problem.
Nevada Tumbleweed |
Re: 1988 no spark
Thanks for the tip, AZT
Re: 1988 no spark
What about a fusible link? Those things are common for burning out. All they are is a smaller gauge wire in the line of two larger ones. You can recognize them by the heatshrink tubing around them. Check the schematics for where they might be. They can still work, but be resistive, which is why they're a pain.
Re: 1988 no spark
Thanks Cow,
I'm just heading back up there tomorrow, so will see if we have any luck with it. |
Re: 1988 no spark
Reply back. I want to know how it goes.
Re: 1988 no spark
I'm not sure about your year car but my 1990 has the infamous TFI module located on the distributor. The TFI module could cause a no spark condition.
