Old 05-15-2005, 01:37 AM
1986camaro 1986camaro is offline
clicking noise in engine
there is a clicking / knocking noise coming from my engine. it clicks when i accelerate but not really when im idling. it started today, and today i used the heat because it was cold, dont know if this info could be a part of it? its a 350 crategoodwrenchTPI Thanks for your help
Old 05-15-2005, 12:17 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: clicking noise in engine
How many miles are on the engine? My guess would be a lubrication problem but that is pretty rare on a new engine.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 05-15-2005, 02:51 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
are you runnin headers or manifolds, you may have a broken exhaust bolt, i had the same thing on my car
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-16-2005, 12:39 AM
Vortec350S10 Vortec350S10 is offline
take a long screw driver and hold the handle end on your ear and probe around the engine with the tip and you should be able to hear where the knocking sound is loudest. If it knocks the loudest when you rev it up and down, and is quiet under a constant RPM it could a rod bearing. If it's just a little tap it could be in the valvetrain. Hook up a timing light and try to determine if it knocks on every flash or every other flash. If you can tell you'll know if it's the valvetrain-everyother flash, or the bottom end-every flash. Hope this helps
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 05-16-2005, 01:31 PM
thanks for the help guys, im going to have my uncle help me check it out here hopefully soon, do you think it is okay to still drive for a couple weeks? thanks!
Old 05-16-2005, 02:48 PM
That depends on how severe the problem is and whether or not you want the car to work for a while yet, you could be doing some serious damage.
2006 Hyundai Sonata
Old 05-16-2005, 03:32 PM
iwilkerson iwilkerson is offline
I had the same problem, the sound dont come all the time and I have had this before, on mine the flex plate was cracked, It sounds just like the engine it knocking, auto transmission, take off the inspection cover that covers the flywheel (flexplate) get a light and a screwdriver and move the flywheel and look real close to the center of it, it can be very small but it make a very load noise. Hope this helps, its only about a $50 repair if you do it yourself,
Old 05-18-2005, 11:23 PM
bag91's Avatar
bag91 bag91 is offline
Re: Re: clicking noise in engine
Might want to check your oil level..
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 05-20-2005, 09:13 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
are you sure the knock sensor is hooked up an ok?
