OK this is the problem to make a long story short i am not getting any power to the feul pump in my jetta i bought a new relay nothin....i even tested the pump...worked....but when i put a test light to the peace that goes into the pum...nada ..nothing so i checked the fuse nada i am not even getting any power out of it(should i be,, am i doin something wrong..plus i just replaced the trans but i checked for a wire i might have pull out....please anyone anybody please is there a solution to this and a easy one at that.please let me know...
Thanks Last edited by prophetecks; 05-15-2005 at 06:42 AM. |
Re: 1994 jetta feul pump problem
Put a jumper wire in the relay panel where the two larger pins of the FP relay (#4 & #6, the two that are perpendicular to each other). You may want to ensure there is power on #6. The FP fuse (#18)should be hot or the fuse box has burned out internally. I have seen this a few times.
still problems
did it nothing ...is there anything else casue i am not getting spark and nothing to my fuel injestors either,,,and if the the coil is bad will the effect the fuel pump????????????
relay
is there a relay for the ecm unit could this be thje problem
If you had 12V+ on the fuel pump relay pin #6 & jumpering it to pin #4 still didn't give you power on fuse #18 then the fuse box is fried.
Do you have the key turned when you are doing this? There won't be power to the pump without the key turned.
I don't believe so, but you can have it on & it won't hurt anything.
still nothing
ok i did what you told me to do with the relay everything checks out good but still nothing ...i had changed the transmission prior to this problem and i am really hesitant to take to a garage and for them to tell me i forgot to hook up a ground some where.....right now i am at the piont where i don't have cash so i wanna figure this out......please i need help!!!!!!!!!
I'm having the same problem. I removed/fixed the trans a few months ago though. I just replaced the fuel injectors last weekend, then fired it right up. Drove it around for a while then parked it - came back and had a fight with the alarm system. I hate that thing. I read on here how to disconnect it, so I did. Now it just cranks and no fire in the hole. I pulled up the trunk matting behind the back seat and checked for voltage to the pump. There's 4 wires: red/wht, purple/blk, org/blue, solid org. The only one with voltage was the purple/blk and it only had 4.5v. The relay clicked when the ignition was turned on and fuse 18 isn't blown. WHAT THE CRAP is going on here! I'm gonna try to jump it tonight to see if the battery is dead since it isn't cranking fast anymore, but still - what a stupid car.
well i just took my ca to the garage 2 days ago am dthey can't find the problem yet soooooo..when i do i will definetily post it................
Damn It !!!!
it was the computer that was giving me this problem......stupid ass part....so maybe this might help other people ...
I was having the same problems, replaced my computer and still justs cranks!!!! When the weather breaks I'll be back to troubleshoooting.
I am having a similiar problem (working on a car for a friend) this is the first Volkswagon ive worked on
When I jumper #4 and #6, I can hear the pump come on.. The relay is tested good, and when I turn the ignition on, 12V is sent to the FP relay.. I found out that the FP relay isnt getting a ground.. (the smallest pin on the FP relay right?) In the manual, it shows that the FP relay gets a ground signal from a Digifant computer??? anyone have any ideas?? gettin desprate?
1991 Camaro Z28 |
