Old 05-15-2005, 12:17 AM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
Bad Gas??
Ok, i got spark, compression, fuel. I dont know what else to check for i have checked all my wires and this is what a came up to.
The car has about 1/2 a tank of gas. It doesnt smell good and the car has been sitting for a good year to a year and half. Could the gas not be good any more? The car almost started a couple of times and you could hear it ignite but then it stopped doing it.
If i do want to get rid of the gas, i know which wire turns it on then i could just undo the gas line from the engine into a bucket. Would this work or would it mess up the fuel pump?
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-15-2005, 12:22 AM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: Bad Gas??
Sounds like it could be... U can try to put in some good gas with some gas treatment or injector cleaner, see if that helps...
Old 05-15-2005, 12:28 AM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
Re: Bad Gas??
yea i think your gas has been sitting too long. get that old gas out and shoot some new fuel in.
Old 05-15-2005, 12:44 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Old 05-15-2005, 12:55 AM
Re: Bad Gas??
Thanks, If its not the gas what else could be the problem? Gas is getting through the line and going out back to the return line like its supposed to but im not sure if the injecters are squirting it in. How do i check my ECU?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-15-2005, 01:31 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Bad Gas??
you know i had gas sitting in my tank for almost 3 years, my car started right up. so your gas aint bad, it doesnt go bad in a asense that it wont start up your car. you will just lose all its octane rating so to speak
Team Lonely Drivers
Old 05-15-2005, 01:38 PM
CivicSpoon's Avatar
There is no Spoon
Re: Bad Gas??
I don't know. I've had bad gas before (in my '90 Olds), and it would start but it sputtered out and died. When I drained the gas and put new in and used some fuel system cleaner, it started and idled perfect. I'm also in NY, so maybe the warm/freezing/warm/freezing crazy weather had more to do with it than just being old gas.
Old 05-15-2005, 02:59 PM
Re: Re: Bad Gas??
What happens is dirt and sut settles on the bottom of the tank, and mixes more with the gas than it would if u use the car often, since it sits for much longer... Plus the gas lines and injectors will dry up, and dirt will also settle in there causing these problems... So when someone says 'bad gas', it dosnt mean the gas itself 'went bad', it simply means it got dirty from sitting...
Old 05-15-2005, 09:34 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
instead of doing that and maybe finding out that that wasnt it, get some carb cleaner, have a buddy spray it into the throttle body while cranking the car with the throttle somewhat open. if it fires up then dies out, then yea, you got some shitty fuel.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-16-2005, 09:35 PM
anthony90si anthony90si is offline
Re: Bad Gas??
i had gas sitting in a parts integra i had. it was in there over a year and a half and the car started right up. then i took the gas out to put in my civic. lol oh and my dads oldmobile was sitting for 4 years and it started up.(it is an old v8 though those are less fussy but still..)
stock b18a1 14.97 @ 92 mph
