Old 05-14-2005, 10:30 PM
Faze3's Avatar
Faze3 Faze3 is offline
Resetting Oil change reminder
So I changed the oil early. I wasn't due for another couple of hundred miles. I decided that since I was changing the oil on my wife's Camry, I'd do the truck too.
I went to reset the oil change reminder per the manual, only now it comes on instead of being reset.
I don't remember - am I supposed to wait until the battery light goes off before pressing the pedal? I tried both.
Old 05-14-2005, 10:52 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i am pretty sure that you just turn on the key and then put the pedal to the floor 3 times and then turn the key off and then start it and it should turn it off
Old 05-14-2005, 11:05 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Resetting Oil change reminder
That's what I just did
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-15-2005, 06:15 AM
Faze3's Avatar
Well damnit, that's what I'm doing and all it did was turn the message on. I tried doing it immediately and also waiting until I saw that the battery light had gone off. Its not like its the first time I've done it. But its the first time I've done it *early*
Shiat..
Guess I'll give it another whack when the family's awake and when its a little later than 0515.
This leads to another question:
5W30 or 10W30?
I've been putting 10W30 in despite the fact that the filler cap says 5W30. I don't really know the technical differences between the oils (except not to put 20W50 in any engine unless its damned old).
Old 05-15-2005, 07:04 AM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Even if you do the reset the computer may take a few on off cycles including going down the road to acknowledge it. I got mine done and after a day I went to the dealer and the second I pulled into the service area it quit lighting up.
When you are board and have a LOT of time here is everything you need to know and a lot more than you wanted to know.
http://www.trustmymechanic.com/motor-oil-bible.pdf
Enjoy
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 05-15-2005, 09:04 AM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
turn the key to the on (not start) position twice then leave it (on, off, on). Then put the gas pedal to the floor 3 times. I'm pretty sure you can do this at a normal pace, but I do know you need to do it before the batt light goes out. After the gas pedal thing, just sit and wait for the 'change oil' light to flash a few times then it will go back to the batt light. Thats when you know it worked. Good luck.
remember..... on, off, on, gas, gas, gas....wait for the light. It should flash with in ~10-15 secnds.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 05-15-2005, 10:12 AM
Faze3's Avatar
Ah. TWICE. I could swear my manual didn't say that. I'll give that a shot. Thanks.
Old 05-15-2005, 11:26 AM
My manual just says turn it "ON" and hit the gas 3 times and the oil light will flash a few times. And that worked. I have an '02
Old 05-15-2005, 11:36 AM
Faze3's Avatar
Yeah, mine says that too. Unfortunately, when I turn the motor over, the light comes on now. I'll try jeep_cj4x4's suggestion and see.
Thanks.
Old 05-15-2005, 12:23 PM
Faze3's Avatar
That got it. TWO turns to Run.
I'll have to make a note on that page in my manual.
Thanks!
