Old 05-14-2005, 07:13 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Anyone who knows timing belts replacement?
Many questions below in BOLD TYPE.
To be safe with my just purchased 147,000 mi used Geo Metro,
today I replaced my 1.0 L. '93 Metro's timing belt and tensioner pully
with a NAPA "Timing Component Kit" item number 2521660.
Lord God, the main crankshaft pully rotated while I was putting the
new belt in! And the car was in first gear! I DON'T KNOW WHERE IT
WAS ORIGINALLY !
Anyway - I put the belt on and I rotated the main crankshaft pulley
twice with the plugs out as told to do in the Chilton Manual.
Worked OK - nothing jammed. BUT - the engine would not start!
The Chilton Manual says to align the timing marks (???????)
That's it - nothing else - no diagrams or photos !!! What the Hell
does that mean?
I called a mechnic I know and he said to set the crankshaft pully
timing mark to Top Dead Center and the camshaft pully timing mark to
the notch on the camshaft housing. I did.... It had been off maybe
20 degrees past TDC after it had rotated. Yikes!
The car works now.
FIRST QUESTION....
Did I do it right?! I am worried...... Engine runs!
SECOND QUESTION...
HOW TIGHT SHOULD THE TIMING BELT BE ? Chilton gives no hint.
The new tensioner pully got quite hot and I hear a whoosh-whoosh
sound. It was hard to turn new but after running the engine for
maybe 10 minutes and taking it out, it rotates more easily.
Just needs wearing in...? God - I hope so - $44 each from NAPA.
The tensioner pully has a spring on the tightener lever, but one has
to tighten both the pulley bolt AND the lever bolt down - so what
the heck is the spring there for !!??
THIRD QUESTION.....
SHOULD I RETIME THE ENGINE via a timing light on the crankshaft
pully mark?
FORTH QUESTION....
The NAPA kit and the Chilton Manual both say this 1.0 L. Suzuki
3 cylinder engine is AN INTERFERENCE ENGINE
Two people and somone on this forum say is is A CLEARANCE ENGINE.
WHO IS RIGHT !?
DoctorBill
Old 05-16-2005, 08:23 AM
crazyinkc crazyinkc is offline
Re: Anyone who knows timing belts replacement?
The 1.0L non turbo is not an interference engine so don't worry about that. I set my belt by feel so I set it to where it has about 1/2" deflection on the long side. Just check the ignition timing and drive. You'll be fine.
Old 05-16-2005, 11:45 AM
DOCTORBILL's Avatar
Geo Metro Lover
Re: Re: Anyone who knows timing belts replacement?
I have an older timing light that connects to the battery's Pos and Neg
terminals and the third to a spark plug wire.
That should work OK - no? Any plug should work also as each
plug gets power at 5 deg BTDC - yes?
Or should I just use cylinder 1,2 or 3's plug wire?
The Chilton Manual has me jumpering God knows what and I don't
understand all of what it says.
DoctorBill
Old 05-16-2005, 12:15 PM
DOCTORBILL's Avatar
Geo Metro Lover
[quote=crazyinkc]The 1.0L non turbo is not an interference engine so don't worry about that.
I have been in arguements with people who say that it is an
interference engine.
Can you tell me where you found out that the non-turbo 1.0 L
engine is a clearance engine - so that I can argue with some
authority?
Thanks for the comment and info!
I changed the Timing Belt and set the timing marks and I'd swear
the car has more power today... But now the beeper in the car
goes nuts until I remove the key - didn't do that before.
Maybe I need to disconnect the battery for ten minutes to erase
error codes on the ECM.
DoctorBill
