Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 05-14-2005, 05:17 PM
lynx5 lynx5 is offline
new short ram intake messus up sensor 02 sunfire
hey i got a 02 sunfire and i recently bought a vibrant short ram intake for it and i installed it and plugged the sensor in but after about 30 mins of driving the T/C light comes on and then the gear changing gets messed up (from 1 to 2 gear it shifts really hard littlekickback andnoise) very not good so anyways i ended up taking the intake off putting the stock back on then drove around and 30mins later it went back to normal driving T/C light off and smooth driving so im wondering why this happened what would cause just performance intake to mess up the computer there and cause problems is this somewhat common? any ideas orsolutions? would appericate it thanks, Steve.
Old 05-14-2005, 11:45 PM
MiniTransAm's Avatar
MiniTransAm MiniTransAm is offline
Send a message via AIM to MiniTransAm Send a message via MSN to MiniTransAm Send a message via Yahoo to MiniTransAm
Re: new short ram intake messus up sensor 02 sunfire
What kind of intake?? You probably installed the sensor wrong. Especially if you reinstalled the old intake and it went back to normal.
Expect alot of yourself, nothing of others.
Old 05-15-2005, 12:29 PM
Its a short ram intake made by "vibrant" for the 2.2L sunfire non ekcotec, what consits of installing the sensor? all i did was unplug the sensor out of the old intake, put in the new intake plug the sensor into the new intake where the slot is for it, thats it right? no programming required? or am iwrong? thanks.
Old 05-15-2005, 09:31 PM
No shouldn't be any programming required.
However, make sure you take the actual sensor out of your old intake! The sensor is what the plug connects too. It should pull right out, and your new intake should have a spot to put the sensor. Just make sure you don't damage the sensor when your swapping it.
Old 05-16-2005, 08:21 AM
yup i took it out and put in the slot in the new intake fine but for some reasons its not reading it right just messes it up, i read after installing the new intake u can unplug the negative cable from the battery for 5 mins to reset your computer so it can learn of the new intake but it says do so at your own risk blah blah.. so im wondering how safe it is? to reset your computer i wouldnt think it could be harmfull but? anyways thanks, anyone else any ideas please? would love to get my intake in again and working!
Old 05-16-2005, 02:46 PM
ok i found the problem i didnt relize there was more to the sensor another half and that was still left into my old intake so essiental i guess i hade the sesnsor for the air intake completelly not working so anyways fixed that and evyerthing is good! car runs a lot faster now its very nice, one question tho is it ok to have the air filter hanging down there in the open? not bolteted to anything? also having the blue rubber band around the end of the intake and the metal tightening clip thing touching the engine just a bit? didnt seem to matter yet atleast.
Steve.
