Old 05-14-2005, 03:18 PM
rwcrazy rwcrazy is offline
Transmission Problems HELP PLEASE !!!
I have a 97 T&C with 117,000, about 20-25,000 ago I had a flush and fill on the trans. It leaked a little fluid since then, but I always kept it level, never low. When it is cold out we have to warm the car up so it will go in reverse, now today it was driving fine I parked came back out after 15 minutes go in and took off, All I have is 1st gear, it wont shift?? Help
I didn't smell anything burning???
Correction it looks like only 2nd gear,
once the trans cooled down it shifted ok, but once it warmed up it started not to shift again
Help
Old 05-14-2005, 11:12 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Transmission Problems
you could have one of two problems:
1. when you had the tranny flushed, did they use Mopar ATF+3? If they used anything else except for that, they could be causing you serious transmission issues.
2. Your TCM (transmission control module) needs to be flash programmed to update its shifting parameters. Only a Chrysler dealer can perform this.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
