Old 05-14-2005, 02:28 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
B18 SWAP Not Starting
Ok im almost done with my swap but it still wont start. I just bought a new distributior and now i have spark. I have fuel coming from the fuel line but i dont think the injectors are shooting it in. What could be the problem? I pulled out the spark plug and its bone dry so i dont think its getting fuel in the engine.
I have checked all my wiring a thousand times and i cant find anything wrong.
Could it be the ECU?
By the way this is my setup:
94 Teg engine
OBD-1 Conversion Harness
94 Teg ecu
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-15-2005, 02:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: B18 SWAP Not Starting
how did you power trhe injectors ?
Team Lonely Drivers
Old 05-15-2005, 04:54 PM
ef four door's Avatar
ef four door ef four door is offline
Double check the firing order. A lot of times when my swaps dont start its just the firing order.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 05-15-2005, 10:28 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
after cranking the engine, pull out a couple of the spark plugs. smell them to see if you smell gas. if not, test the injectors and the wiring going to them. if you do smell gas, double check for spark and check the firing order.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-16-2005, 04:36 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
any codes?
what obd1 harness did you use?
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-16-2005, 05:36 PM
89hatcher's Avatar
89hatcher 89hatcher is offline
Send a message via AIM to 89hatcher
try turning the key on to the on position but don't start it and hear if you can hear the fuel pump trun on....and also try checking any fuses under by the steering wheel if any of the fuses broke or something....hope that helps...
