Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 05-14-2005, 11:20 AM
Syn48 Syn48 is offline
T04b?
Will a T04B garrett turbo fit in our cars? "T5/T6 compressor wheel"
Specifications:
0.60 A/R compressor housing
Inducer dia .2.03".
Exducer dia. 2.75".
P-trim exhaust wheel.
0.96 A/R on center turbine housing.
45lbs/min
Old 05-14-2005, 02:35 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: T04b?
i would believe that turbo would be too big for the 3G. it would probably fit, but with the amount of exhaust the the 4cyl produces, it would take longer for the turbo to spool. the bigger you go, the longer its going to take for the turbo to spool
Old 05-14-2005, 02:45 PM
Thank you for being patient with my posts and replying i am going to go with a T3/To4E garrett but i do have one last question will a 57trim take longer to spool then a 50 trim?
Old 05-14-2005, 04:12 PM
Re: T04b?
i know the garrett is expensive. you could also look into Precision or Turbonetics t3/t04 turbos. they are competitors to Garrett and sometimes they are cheaper..
explanation...
The Exhaust Turbine
The exhaust turbine design is a balance between absorbing as much energy from the exhaust gasses as possible and allowing the gasses to flow as easily as possible. This is closely related to the size of the exhaust housing. A larger turbine can absorb more energy from the gasses and spin the shaft with more torque and speed, but too large a turbine will restrict the flow of exhaust such that engine performance is greatly reduced. Typically, the inducer is only slightly larger than the exducer on the exhaust turbine. Generally, you would want to stick with the stock turbine because it's size is not nearly as important as the compressor turbine's size. If you want to reduce restriction through a smaller housing, you can have the turbine "clipped", which reduces the size of the fins and allows more air to flow around the turbine.
The Turbine Housings
The exhaust and compressor housings on turbo chargers use a "scroll" design. For example, the exhaust housing's scroll is where the exhaust gasses enter the housing and are directed at the turbine. It's basically a smooth, tubular chamber that surrounds the turbine with a slot all the way around that acts as a nozzle to direct the exhaust gasses at the turbine. It's called a scroll because it slowly gets smaller in diameter as a goes around the turbine. This pressurizes the gasses, forcing them out of the slot/nozzle at a fast rate. In turbo-terms, the scroll is measured by the cross-sectional area of the scroll's "tube" (A) and the distance from the center of the "tube" to the turbine shaft (R). The values by themselves are not meaningful to the user and for the most part, R does not change much for different housings, but by dividing R into A, you get the A/R ratio. So, the A/R ratio of the exhaust housing refers to the size and shape of the scroll that is cast into the housing. It basically determines how restrictive the housing will be, versus how quickly the turbine will spin up. A lower A/R ratio (smaller scroll area, A) results in a more restrictive housing. This restriction speeds up the exhaust gasses and increases the amount that the gasses will expand. It's the speed and expansion of the gasses that causes the turbine to spin. So with a low A/R ratio, the turbine will spin up quicker, but as engine output and rpms increase, the restriction of the housing begins to build up too much back pressure on the engine, which reduces performance. A good rule of thumb for when there is too much back pressure is when the pressure in the exhaust manifold is more the half of the pressure in the cylinder. So basically, a larger A/R ratio will improve your engine's top end, while losing some mid range power and increasing turbo lag. A smaller A/R ratio will help the bottom and mid-range, but may effect the top end.
On the compressor side, the housing also features a scroll design, but it has the opposite function. The air leaving the compressor turbine has a lot of speed, but not much pressure. The scroll on the compressor housing starts small and gets larger as it approaches the compressor outlet. This collects the air and builds up air pressure. So, the compressor housing is designed to convert the speed-energy of the air coming off of the compressor turbine into pressure-energy, which is much more useful to an engine.
The Compressor Turbine
The size of the compressor turbine determines the maximum amount of boost that the turbo charger can produce. It also effects the spool-up time of the turbo. The type of compressor wheel is usually designated as its "trim", which is a value that describes the inducer and exducer sizes. Typically, the exducer is significantly larger than the inducer on a compressor turbine.
So in conclusion, a turbo charger's design becomes a balancing act between these three factors.
