Go Back   Automotive Forums Car Chat > Ford > Probe
Old 05-14-2005, 07:03 AM
chelle_shocked chelle_shocked is offline
Unhappy help PLZ 85 PROBE WONT RUN 8(
plz help i am at wits end
i have a 95 ford probe 2.0 16v following a smalll hole in rad temp gauge shot up and car stopped running
cam belt and timing belt is fine there is oil and water in the engine so it hasnt cooked the engine the only problem found so far is ht leads burnt for some reason???
car wont start any ideas on what the problem could be its turning over too fast
Old 06-02-2005, 12:33 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: help PLZ 85 PROBE WONT RUN 8(
check your coolant, no coolant no start. Your rad could be gone/
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
Old 06-02-2005, 06:16 AM
Unhappy
hi thanx for the reply as i said the rad has hole in it but car should still turn over and run without rad for at least 4 mins, there was coolant in there before car stopped running, i have already spent a fair bit on the car and being a single parent im running out of options anything else i can try would be greatly appreciated thanx for your time in replying
chelle
Old 06-02-2005, 06:57 AM
bargersaudio bargersaudio is offline
Turning over fast is a sign of no compression. Are you sure the belt is ok?
Old 06-02-2005, 07:13 AM
Re: Re: help PLZ 85 PROBE WONT RUN 8(
hi thanks for your reply belt is fine and is actually fairly new, it has not slipped, broke, or come off, when the top of the engine is uncovered and car is attempting to start oil shoots out from the top, which i have been told is a sign of compression, i am having a compression test done on the car tomorrow so hopefully i will know more then, thanx for your time, its greatly appreciated, i have had 3 guys who know about cars look at my probe and they are all baffled lol anything else i can try???
Old 06-02-2005, 12:41 PM
Re: Re: Re: help PLZ 85 PROBE WONT RUN 8(
Please let me know what you find out. I am kind of stumped also.
