Go Back   Automotive Forums Car Chat > Honda > Del Sol
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-14-2005, 03:45 AM
ez2plz ez2plz is offline
location of aux light relay???
I have a 93 del sol si and am having trouble getting the aux. lights to work. After aquiring a fuse box diagram I have checked the #11 fuse and it is ok. The diagram states that this fuse powers the aux. light relay and I believe this is the next thing to check, if I could find it.
I should mention that the led on the switch comes on like it should but no lights.
anyone out there with a factory service manual who could give me the location of the aux. light relay???
Thanks
Old 05-15-2005, 01:14 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: location of aux light relay???
The relay is located on the inside of the driver's side fender just in front of the door. Remember to connect the SRS short connectors before disconnecting any part of the SRS wires so you don't accidently deploy the airbags. There's two short connectors - one in the little compartment just underneath the steering wheel (on the steering wheel itself) and one just above your glove box (have to move the glove box stops on either side so it will open all the way down and you can see it from there). The short connectors are little red clips.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 05-15-2005, 07:01 PM
Re: Re: location of aux light relay???
Thanks I'll look for it. However it seems like the SRS short connectors are going to be easier to find and work with than the relay itself. I guess I should invest in a factory service manual and the electrical trouble shooting manual also.
Old 05-15-2005, 08:41 PM
Smile Re: Re: Re: location of aux light relay???
Well I went out to the garage with alittle trepidation on my mind. The first step was to find the relay and I was thinking "how much stuff will I have to remove just to see it and are there more than one and what does it look like etc.)
My wife is a nurse and she brings home those little pocket lights which are very handy for looking in the dark places under the dash and such. So I opened the driver's door and layed down on the garage floor (under the dash on this car is a pain) to see what tools I would need. I turned the light on the area where you described the relay should be and found that Honda had put them right out in the open where you can get at them!!!!! OK Now which one would it be? Well there was only one that didn't have a plug in attached to it (could that be it??). Looking around, there was only one unattached plug. My mind was racing. I bet this is the plug for the relay, I told myself. I pluged it in and low and behold the lights work as they should. I walked away feeling like a master Honda mechanic.
Thanks for your help - even a simple thing like a unplugged plug can be a problem when you don't know where to look.
Thanks again
Jim
Old 05-16-2005, 09:35 PM
No sweat, man. Glad it was easy to get to. As for the Honda manual, they're not too terribly bad. It'll run about $80 but well worth the investment. I used mine to tell you where the relay was.
http://www.helminc.com/helm/Result.a...8S76D02L9D2707
Old 03-13-2008, 05:00 PM
devilhorns44 devilhorns44 is offline
I Have A 1993 del sol and the foglights dont work!! I have found the plug and it is plugged in and also put new bulbs in the sockets, What else can i do???:S:S:S
Life And Sol
Old 03-13-2008, 05:48 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
please dont bring up old threads, thanks.
Closed Thread
