im in the process of replacing my oil pump, due to loss of pressure (read about it in the problem section).
anyway i was wondering if theres any additive you guys have come to like when it comes to higher mileage? <--117K and little puff of smoke on start-up. and what weight should i use, just factory recommended 5w30? |
Re: oil type or additive needed?
no one here uses oil in their high mileage vehicle?
My Camaro has 201,500 miles and I use 10W30.
![]() Quote:
That little puff of smoke on cold start up is leaking valve guide seals, just in case you were wondering...not a big deal...
![]() '89 S15 4x4 350TBI/700r4restored body, paint, 3" lift, crane cam, vortec heads '88 Iroc 350 carb, TCI 700r4, 380hp |
I also use 10W30 on my 89. Im not sure how important it really is. Myself im not too worried, I change the oil at the start of every summer and thats all she gets!
use those "high mileage" oils... and even some of those additives that is supposed to raise compression back up. just go to advance, look at the oils and additives, read about them and determine what u wanna use...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
i've used 10w40 since day 1
