Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-11-2002, 12:50 PM
LX98Civic's Avatar
LX98Civic LX98Civic is offline
Send a message via Yahoo to LX98Civic
DIY camber bolts! Info on strength of bolts! Someone please translate!!
I posted this is a non-auto forum:
I purchased some 10m 1.25 X 40mm bolts from ACE hardware and the guy said the bolts were pretty hard, but not quite like steel.
Anyone know what the <b>8 8</b> means that is stamped on the head of the bolt? Or is there anyway to find out how strong these bolts are or what they are made out of?
I lowered my car and these longer bolts and washers are to replace the OEM ones since I have 3 degrees of negative camber...
The link to what I am doing ==> HERE
Response someone left:
ISO property classes for steel bolts, screws, studs and nuts
The strength of standard ISO metric steel bolts, studs and nuts is readily identified by means of a numerical code.
Property classes for steel bolts, screws and studs
The code is comprised of two numbers separated by a dot. This dot is not a decimal marker but is merely a means of separating the two parts of the code. The number to the left of the dot when multiplied by 100 provides an indication of the Ultimate Strength in Mega Pascals (MPa) while the number to the right when multiplied by 10 times the preceeding number gives the Yield Strength (Mega Pascals - MPa) or Stress at 0,2% Permanent Set (MPa) depending on the property class; e.g. 8,8
Ultimate Strength
8 x100 = 800MPa
Yield Strength or Stress at 0,2% permanent Set
8 x 8 x 10 = 640 MPa
Property class Designation for Nuts
The corresponding code for nuts is a single number and is derived from the left hand number of the property class of the bolt, screw and stud. This number when multiplied by 100 indicates the Proof Load Stress of the nut in MPa. Thus, for the bolt of property class 8,8 in the above example a nut of property class 8 is required. This nut will have a Proof Load Stress of 8 x 100 = 800 MPa
In practice only standard threaded fasteners in the high tensile property classes, i.e. property class 8,8 and above are required to be marked with the appropriate code.
http://mdmetric.com/tech/u19e2.htm
Thanks for any info on this! From what the person said, you think the bolts I have are strong enough?? I'm going to be using about 4-5 washers on each bolt
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77----------------
--- --- --- -- Sleeper in the middle -- --- --- ---
Old 04-11-2002, 04:45 PM
Rice-Rocketeer Rice-Rocketeer is offline
Re: DIY camber bolts! Info on strength of bolts! Someone please translate!!
Dude, why are you stressing over this? There have been MANY countless ppl who have done the bolt trick and I have yet to hear of anyone breaking a bolt.
Lookin at my gucci, it's about that time...
6 Bolt & 7 Bolt Info Needed talon-95 Engine, Transmission and Drivetrain 3 08-08-2006 09:17 PM
i'm new to this, can someone please help me w/ info nataku12 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 02-26-2004 02:31 AM
ghetto DIY Camber kit boosted k20 Integra 4 01-08-2004 10:37 PM
can someone please do me a HUGE favor PLEASE..... discented '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-10-2003 08:06 PM
Can someone please photo-chop this lancer for me, please??? integra818 Graphic Manipulation 12 04-09-2003 12:01 AM
