Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-13-2005, 07:05 PM
tntone tntone is offline
Question Need help with 2000 4-Runner O2 snesor
I have a 2000 4-Runner with a check engine light, Toyota said it was reporting a "lean" mixture and told me that it was because of the brand of gas I was running, or a bad O2 sensor.
1 - how many o2 sensors are on a 2000 4-Runner, there are, what looks like 2 - one before the cat and one after?!?!
2 - if there is only 1, which one is it, front or back?
Thanks
Tim
Old 05-13-2005, 07:59 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Need help with 2000 4-Runner O2 snesor
Welcome to the AF!
What code did the ECM report? Other things can cause a lean error code besides the HO2/A-F Ratio sensor.
(There are two sensors, one before and one after the cat. converter)
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-14-2005, 01:48 PM
Re: Re: Need help with 2000 4-Runner O2 snesor
Originally Posted by Brian R.
Welcome to the AF!
I didn't get to see the code from the dealer, and the one at the local autoparts store has a broken pin right now. I will get the code read tomorrow and I hope it narrows things down a little.
With there being two sensors, should I replace them both at the same time?
Old 05-14-2005, 07:01 PM
Brian R.'s Avatar
Resident Chemist
No, they have different functions.
I bet the code is P0171.
Read this thread:
http://www.automotiveforums.com/vbul...d.php?t=405771
If it turns out to be an HO2 sensor, then make sure you get the right one. Some trucks have the HO2 sensor and some have the A/F ratio sensor. Get the correct part number from Toyota parts department with your VIN.
