Old 05-13-2005, 06:24 PM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
tranny noise....
i just got my new clutch and flywheel put in. I love it, but there are two problems, that i havent talked to the shop that put it in about (they are closed). First problem, the starter makes a noise just before the engine starts. Never happend before.
Second, i recall a thread about a part that falls out after you do a new clutch install that makes rattling noise when the car is in motion. I remember vaguely that it wasn't a big deal, but im not sure if its that exactly. The rattle is driving me nutz. I don't really trust the guys that did the install because they told me that my starter was making a noise BEFORE i brought it to them. Thats bullshit. So, recomendations? Ideas?
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 05-14-2005, 02:15 PM
volkerc's Avatar
volkerc volkerc is offline
Re: tranny noise....
Your starter might need to be shimmed. Does it sound like it is hitting the wheel?
Old 05-15-2005, 12:18 AM
the guys at the shop said they tried to shim it, but that that wasn't the problem. beats me
Old 05-15-2005, 03:49 AM
volkerc's Avatar
well, you haven't exactly described the noise it makes. but when you mention noise in that area, this combination comes to mind first, starter hitting the flywheel that is.I don't see what other noise a starter would make...?
Old 05-15-2005, 09:09 AM
its a grinding noise JUST before the engine fires up. Then, nothing. Last maybe a half second. Ever turn the egnition the while a car is already started? On some cars it makes a similar noise to what im hearing.
Old 05-15-2005, 02:58 PM
volkerc's Avatar
so it is exactly what i thought it was. the gear from the starter is hitting the flywheel. meaning your starter needs to be aligned properly to the flywheel.
Old 05-15-2005, 09:36 PM
Re: Re: tranny noise....
So the whole thing has to be taken apart again to align it properly? Man, im gonna have a major argument with these fucking guys. They are lieing to me and i don't like it.
Old 05-16-2005, 10:53 AM
volkerc's Avatar
Re: Re: Re: tranny noise....
not the whole thing...
just the starter itself needs to be losened and bolted in correctly to lign up properly with the flywheel, and that is usually done with shims...
Old 05-16-2005, 07:35 PM
Re: Re: Re: Re: tranny noise....
gotta drop the tranny tho right?
Old 05-17-2005, 06:03 AM
volkerc's Avatar
Re: Re: Re: Re: Re: tranny noise....
i doubt that. as far as i know the alternator mounts from the front. and is usually held by two bolts.
see what the starter does is, the solenoid on top actuates some sort of lever inside the starter that pushes a rod that has a little gear at the end towards the flywheel, and then starts to spin the flywheel. so if the gear that comes out does not exactly engage with the flywheel it will hit it and create that noise you are talking about.
