Old 05-13-2005, 05:22 PM
cnj101 cnj101 is offline
auto trans 5.0 ..how to tow
Is it ok to tow a 91 5.0 auto trans with a tow dolly leaving the rear wheels rolling on the ground, or should the rear wheels go in the dolly leaving the front wheels on the ground?
Old 05-13-2005, 08:05 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: auto trans 5.0 ..how to tow
i would take out the drive shaft and plug the transmission so you don't leak fluid. imo
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 05-13-2005, 10:28 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I think you are confusing a dolly with a wheel lift.
Dollies are that set of 4 little tires on 2 axles that goes underneath the wheels that are on the ground. This allows the car to be towed without any car tires rolling on the ground.
Do not tow an auto trans car with the drive wheels turning, unless you remove the driveshaft, (which is a pain in the ass)
The best and safest way is to place the front wheels in the wheel lift and slide a set of dollies under the rear or disconnect the driveshaft.
You can lift the rear end with the wheel lift and have the front tires roll on the ground. This is a bit dangerous because if the steering wheel shifts, the front end can hop sideways into other traffic.
So you MUST tie off the steering wheel, so it will NOT move. Do not rely on the ignition lock for the steering wheel.
