Old 05-13-2005, 05:26 PM
sanzoneb sanzoneb is offline
second gear problem
Second gear is grinding when i try to shift out of first at a high rpm[anything higher than 4 and a half]. If u shift out of first at a low rpm it is smooth. Everyother gear is smooth to. Is my transmision shot. Any other ideas what it could be.
Old 05-13-2005, 05:52 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: second gear problem
synchro
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-13-2005, 09:26 PM
How much is it to replace and is it a painful job
Old 05-16-2005, 10:48 AM
Igovert500's Avatar
blue + red light magnet
The part is only like $80 at kormex, however, some tranny shops wont do the work because they don't want to warranty it. So just search around until you find someone who will swap individual synchros. If you do a search or PM youngvr4 you will get plenty of information.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
