Old 05-13-2005, 03:41 PM
alincosma alincosma is offline
rear speakers
I ahve a GA GT 01 and the rear speakers are burn out. I want to replace them but I don't know how to get the old ones off. I got some speakers from another GA but this seems complicated. Can you give me some clues? Thanks
Old 05-14-2005, 02:05 PM
SupaFly_ SupaFly_ is offline
im pretty sure the top covers come off & they remove from the top.... in a 96 & older they went in thru the trunk... should just be 4 screws & a plug for each speaker
Old 05-14-2005, 02:57 PM
Re: rear speakers
I tried to take the top off but I think it has a click, something that I don;t know about. I can't do it from the trunk. I got the other speakers from a junkyard so I know because I had to take them out off that car, but I still couldn't figure it out how to take them out with out distroing the top.
Old 05-14-2005, 05:11 PM
Knifeblade Knifeblade is offline
Re: rear speakers
http://www.autozone.com/servlet/UiBr...3d800e599d.jsp
K, this isn't as current as your ride year, but scroll it, may may help ya visualize how to access the rear speakers.
Old 05-14-2005, 08:07 PM
grandamdriver52's Avatar
grandamdriver52 grandamdriver52 is offline
Send a message via AIM to grandamdriver52 Send a message via MSN to grandamdriver52
Re: rear speakers
the 96 and older, supafly, still come out threw the top and not the trunk. I know that because i replaiced them with sony xplode 6X9 and it was a pain to do. i think it still might be the same but im not totaly sure.
Old 05-14-2005, 08:39 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: rear speakers
For your 01, you will need to remove the top shelf, but before you can do that, you will need to remove the two side covers that run up above the back seat windows. After they are off, you can remove the soft carpeted cover by pulling up hard, and that will expose the speakers. You can release the speakers by laying in the trunk and pushing on and releasing the clips holding them in - they will then be able to be pushed up and taken out through the inside of the car.
