Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 05-13-2005, 03:17 PM
jeanniereeves jeanniereeves is offline
Bravada acts like it is going to die and bogs down
I have a 98 Olds Bravada. It has 154,000 miles on it. It started to act funny a couple months ago, where it acts like it is either not getting gas and bogs down, this happens in town and on the interstate. At first I thought it was the transmission because it seemed like it was not shifting correctly, but now I think it is more bogging down from something else. Someone told us that it could be the EGR valve. We took this off and cleaned it out the best we could. It seems somewhat better afterwards, but the problem was still there and then got worse again after only a few days. We purchased an EGR valve off ebay that is used and a GM tech guy refurbished it. He had wonderful feedback and sells tons of these refirbished EGR valves. Anyway after putting it in, I could not tell that it was boggin down while driving in town, however when I got on the interstate it really acted like it wanted to die going 70 with the cruise was set. It has never died on me yet and I am still not sure what this could be. I guess we could check the fuel filter or something...
Please help.
Old 05-14-2005, 10:10 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Bravada acts like it is going to die and bogs down
Sounds like low fuel pressure, I'll check my book.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 05-14-2005, 11:04 PM
we are going to replace the fuel filter tomorrow. We will let you know how it works out.
Old 05-18-2005, 01:02 AM
AF - Advisor
Sorry for the delay, you should be getting 60 to 66 psi at the Schrader Valve pressure test port near your fuel injection on top of the motor when you turn the key on but not start the motor and 56 to 60 psi while the motor is idleing.
Is the Check Engine light on?
How long since the last sparkplug/plug wire replacement?
A remote possibility is one of the O2 sensors not "seeing enough oxygen"...low voltage but not enough to set a trouble code(DTC) and causes the computer to keep cutting fuel back because it thinks the motor is running too rich due to the low temp/voltage from the O2 sensor. This is makes a scanner necessary to diagnose.
Old 05-18-2005, 01:39 PM
Okay, we replaced the fuel filter and it still runs like crap. We replaced the coil pack and put in higher octane gas with a bottle of cfoam. We took to AutoZone and a code of PO300 came back. The plugs and wires were replaced about 3 months ago and the fuel pump was replaced 6 months ago. The only other thing that I see on the net about the misfire code is the fuel pressure regulator or something like that. The bad fuel was one of them too and maybe it will take a while for the cfoam to work, but I really want my Bravada to run better. Thanks for your help.
Old 05-19-2005, 10:45 AM
clariveros's Avatar
clariveros clariveros is offline
check your fuel pump like chris said first, then also pull the negative batery cable, wait for computer to reset, and then get the codes, ur problems does not sound like a misfire, bad o2 sensor maybe, good luck
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 05-19-2005, 11:29 AM
The fuel pump is brand new and we did reset the codes before getting the Po300 code. We had the battery disconneted while putting in the new fuel filter.
Old 05-23-2005, 06:37 PM
Schrade Schrade is offline
I thought I had a tranny problem, but this past weekend, I read 650 blazer/bravada/jimmy 'posts', and I got my 'tranny' problem solved 100%. It's the ign. switch, and it's intermittent, and can be proven by unplugging the battery for a few minutes. It clears the codes, and faulty positives are reset. Doesn't sound like the switch, but try again...
Old 05-23-2005, 06:42 PM
Hey Chris, I think you're a little off, on the O2 sensor function...
WAY BAD CALL 94JIMMY!!!
A finely tuned motor does NOT even use the O2 sensor. A finely tuned motor uses ALL of the O2 which gets burned in the combustion process, and the O2 sensor does no work. A poorly tuned motor lets O2 get through the combustion process (by not burning it all), and into the exhaust, and the O2 sensor tells the ECM that compensation is necessary to fix another problem. If you'd like to see that in print, I'll be happy to get it to you. A bad O2 sensor is an extremely common myth!!!
Old 05-24-2005, 05:48 PM
AF - Advisor
Re: Re: Bravada acts like it is going to die and bogs down
Allright! Yeah, send it to me, I accept all the help I can get.
Old 08-20-2005, 12:07 PM
MHBolton MHBolton is offline
jeanniereeves,
If you are still having the problem, try cleaning the carbon out of the plenum. I had all kinds of trouble at lower speed (stalling out) on and off, and replaced the EGR etc. Sometimes it seamed like replacing the front left spark helped as well (it burns hotter than the rest on my '94). Finally I had a BETTER mechanic figure out about the plenum. He said it was fairly common, design related. One note however, make sure all the lines to the plenum are cleared out or the problem could pop up again. Good luck
