| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
tamiya spray problem (metallic paint)
Hi, I'm asking you for my friend for some help about this problem:
Paint before painting had good temperature and it was mixed for quite a long time (about 3-4 min) but after painting some "marks" appeared, it looks like the paint wasn't mixed properly. He wasn't painting from very short distance, so it propably isn't a paint run. There are two coats of primer and two coats of paint here. I really don't know what to think about that, anybody? ![]() ![]() ![]() ![]() *Sorry for my English...
Kuba, Poland
Re: tamiya spray problem (metallic paint)
It looks like you may have sprayed too thick of a coat and it ran.
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
Your coats was too tick. you should make many light coat.
![]() CarsModeling.com. My Scale Model Cars blog. |
For two coats it's definately too thick. Looks like the panel lines are starting to fill up. Just drop it in some dot 3 brake fluid for a few hours, scrub with an old tooth brush to get all the old paint off and start over. This time use light mist coats.
You said he was painting from a very short distance, he might want to back the can up a bit from the model. |
at first You should spray one mist coat !
(and wait when it will dry) Wet paint has mixed with "fresh primer coat" !!
![]() MERCEDES-BENZ SLK 230AMG /FUJIMI 1:24/
Definetly a case of "paint running". First of all, let the primer dry, there are as many opinions as modelers about how long you should wait, but take a day to be on the safe side.( you have other parts to work on,right?)
Then mist on a coat, meaning a quick pass with the can. Try not to cover at this stage. wait a while, mist some more. Patience,people,patience ..If you run a paintjob, the paint will, eh..run.
Newsflash: Diecast sales fund terror activities. |
cześć Kuba!
Is that Tamiya TS alumimum? If yes I had (almost) the same problem. It definately in my limited experience seems more prone to running - it is somehow "runnier" and really needs lighter/finer coats. stevenski |
This paint is very liquid and allthou it does not have usual paint run thick marks it is paint run for sure. Be extra carefull with metalic paint because they are very thin. Allthou it would be good to strip all down and start again you may rescribe the panel lines, slightly wet sand complete body and recoat it but be carefull not to sand through the paint as you will not be able to hide that. And make at least 3-5 very very light coats and I think one heavy will be eneugh (let it dry first for at least 30 minutes).
+1 on the 'paint run' , that's happend to me. The good news is that if you don't see a bulge when you look at it from the side, you can just add a couple of light mist coats over that and the color will even out. You're basically just covering it up. But make sure you scribe out your lines a little. Or you can just strip it down if the 'bulge' from the runny paint is noticeable (enough to irk you anyway).
Ed- |
Thank you all for help. We'll remember that for sure
Kuba, Poland
