Old 05-13-2005, 09:46 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Musashi needs a motormount
besides the dealer and 3sx, where else can I find the rear motormount? the one between the engine and the firewall.
$100.00 is a bit much for 10 bucks worth of rubber and 12 bucks worth of steel!
I called NAPA, Autozone and Automotive Parts and Machine, they dont list them at all.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 05-13-2005, 09:52 AM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Re: Musashi needs a motormount
Why not take the plunge and go all solid motor mounts?
Old 05-13-2005, 11:21 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
your best bet is to check salvage yards (www.car-part.com) and 3si parts for sale section (http://www.3si.org/forum/forumdisplay.php?f=4)
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-13-2005, 03:58 PM
Im2Fast4U Im2Fast4U is offline
Alot depends on what type of motormounts you want. OEM replacements might almost be harder to find than if you go to poly mounts or even solids.
1993 Dodge Stealth
yes, it has mods....
R.I.P. DAD NOVEMBER 3, 1952-NOVEMBER 25, 2002
I LOVE YOU
Old 05-14-2005, 12:57 PM
stfuad's Avatar
I just remembered you can clean out the rear mount and inject either poly urethene or some other type of material in there. I forgot what it's called but it's basically the same as having a solid mount.
Old 05-14-2005, 06:11 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
I just had the same mount rerplaced it was 100 bucks at a dealer and thats prettty much the only place you can find the oem. Did the swap at amco transmissions.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 05-14-2005, 09:08 PM
Hotshot8792 Hotshot8792 is offline
I've got all 4 stock motor mounts sitting around. I have solids on my car now. 3 of the 4 are in perfect shape, one has a slight rip in the rubber, but nothing as bad as i have seen in the past. I'm sure i can let all 4 of them go for $40 + shipping obo.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 05-16-2005, 08:50 AM
I PMed you. thanks.
