Old 05-13-2005, 08:24 AM
riff22 riff22 is offline
Red face leaky ss oil line!
i bought this ss oil line off ebay, http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT of my evo 3 gt and i noticed it is leaking where it threads into the turbo, i think i can make it tighter, but iam worried about striping the treads. can i use thread tape or will it just melt? has anyone else had this problem?
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 05-13-2005, 01:12 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: leaky ss oil line!
did you use crush washers for that?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 05-13-2005, 01:30 PM
no, it wasnt a banjo bolt.. it just came with a fitting that threaded into the turbo. do i need a crush washer with this type?
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 05-13-2005, 02:12 PM
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742 if you scroll down there is a pic of the exact line i have.. is it suppost to be this one a banjo fitting?
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 05-13-2005, 05:56 PM
Killa_DSM's Avatar
I basically have the same type of oil line, but mines for extremepsi.com. I used copper washers for mine with no leaks! So I would try to get a copper washer.
Old 05-13-2005, 06:44 PM
kjewer1 kjewer1 is offline
AF - Advisor
Any time you are not using tapered threads (NPT or BSP) you have to use something to create the seal. With AN stuff its typically an O-ring. In this case (high temperature) a crush washer should prove to be the best option. Viton would probably hold up though since the center section is water cooled. At any rate, you need something in there.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-14-2005, 12:30 AM
joemathews's Avatar
joemathews joemathews is offline
I bought the ss-oil feed line to 16g fitting from Mach V, I believe--$16. Jake and I improvised with a fitting that didn't thread right, and just cemented it in there with locktite. It held great for 4 months But I had to get this fitting to go from the SS oil feed line to create a good seal at the turbo--no crush washers, just torqued down to ~32 ft.lbs. I believe. Double check that--it was something in that area. No leaks
1996 Eagle Talon
Old 05-14-2005, 02:32 AM
AF - Advisor
If its an aluminum fitting it may work without a crush washer, since the aluminum is probably softer than the copper crush washer, or at least close to it. But a straight thread fitting can not make a seal at the threads. It has to happen either at the bottom (like brake/flare fittings) or at the surface (oring or crush washer). But if it works, it works.
Kevin Jewer
Old 05-18-2005, 07:38 AM
i got a crush washer and installed it and it fixed the leak... thanks everyone!!
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
