Old 05-13-2005, 07:53 AM
rwebb001 rwebb001 is offline
Cam preference?
I am almost ready to convert to carb setup on my 87 Iroc 350. The question I have is if I should change out the cam while I'm in the conversion. I wasn't sure of the lift the factory cam had on it or if it would be ideal to leave it in. I will be using a dual plane alum. intake with a Holley 600 or 750.
Old 05-13-2005, 06:41 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Cam preference?
eaisest time to do it is when the engine is out of the car... pretty easy to do. otherwise you probably won't change it. I prefer compcams (see my signature). www.compcams.com
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-16-2005, 06:04 AM
Re: Cam preference?
Only problem is this is my daily driver to work so my work has to be done over the weekend. I'm already changing out the TPI for a carb setup.
Old 05-17-2005, 08:06 PM
stephenp stephenp is offline
Send a message via AIM to stephenp
Re: Cam preference?
ahh what do you want for the tpi setup???????
where do yuo live i want it lol
whats wrong with it ?? live near ny?????
ill remove all tpi and ecu and install your carb..... hell you can drive my 305 terd bodie inj. for the weekend lol
Old 05-18-2005, 08:55 AM
Re: Cam preference?
I am doing a trade thing with the tpi and carb stuff.
