Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 05-13-2005, 02:18 AM
maximagirl420's Avatar
maximagirl420 maximagirl420 is offline
Unhappy Overheating
I need some advice. I have a 94 Infinity J30, 170k. It started overheating so I replaced the thermostat. That didn't help, and it overheats faster everyday. Turning on the heater worked at first, but now it only slightly slows the process. Also, the car only takes about 15-20 mins. to cool down to 1/4 warm from all the way hot. The water pump makes no noises, and the radiator has no leaks, and the hoses in and out of the rad. are new. However, when changing the thermostat, there was a fairly good-size chunk of pink slate-flake-like rock behind it. Further inspection found the housing for the top hose (not to the thermostat on this car) had nearly a quarter inch of this sediment cemented to the bottom. And the radiator has almost a half inch of what looks and feels like dirty Crisco. However, there is no sign of water in my oil. My question is: Do I just need to flush this? Or is this problem a lot bigger than my paycheck?
That which does not kill me only makes me stronger. . .
Old 05-13-2005, 04:23 PM
Will2 Will2 is offline
Re: Overheating
Head gasket blown
Old 05-13-2005, 07:47 PM
Re: Overheating
Actually, I found out it was the radiator. Somebody put so much stop-leak in it, the little slots inside were as thin as my fingernail.
Old 05-14-2005, 04:20 AM
Re: Overheating
This is good. It's a lot cheaper fix.
Old 05-16-2005, 07:42 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Overheating
Keep in mind that someone put stop-leak in it for a reason...
A good cooling system flush would do it the world of good... pull off one of your heater core hoses and get a fire reel hose into your radiator hoses. Get some real pressure in there to clean out your motor and heater core... that way the prob won't come back...
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
