Old 05-13-2005, 01:17 AM
SidewayzS15's Avatar
SidewayzS15 SidewayzS15 is offline
Send a message via AIM to SidewayzS15
Tutorial: Making a Rollback Ragtop
First off i would like to say that i am -Sk8er6811- and if it is possible i would like it to read SidewayzS15 for my subcase and hinge tutorial. Thanks.
This tutorial is going to be applied to a mini cooper. I chose this because the roof is separated already and it was something i wanted to do on one for awhile now. Before we begin you are going to need some materials consisting of...
1. Krazy Glue (Or other type of C/A)
2. A piece of clothe
3. paperclips or sewing pins
4. Fabric glue
5. Square Brass tubes, though circular ones will work as well. The diameter or width of the opening of the hole should be just smaller than a pin head.
6. Sharpie
7. Dremel (Xacto will work too)
8. Your choice of putty
Step 1: First decide how big you would like your rag top opening to be. After you have decided draw it on to the roof with a marker. After marking it cut the area out with your dremel, or slowly scribe the lines with a knife to leave the opening.
Step 2: Cut the tubing to the length of the hole and make sure it fits snugly in the cutout. Do not glue it in yet.
Step 3: Using a thin cut off wheel, carefully cut a channel in the tubing. After the channel is cut test fit again, and glue it into place.
Step 1, 2, and 3 pictures:
Step 4: Cut a piece of clothe to fit in the hole, make sure you make 2 pieces, one for the top and one for the bottom.
Step 5: Cut paper clips that span the width of the tubing you have glued in. Make sure it is not from edge to edge, if it is, it might be a pressure fit which can lead to the tubes breaking or the top getting stuck when sliding back.
Step 6: Glue 1 paper clip at each end of the clothe, then make 1/2 inch intervals and glue other paperclips at those marks (you might need to adjust the measurement depending on hole size and scale)
Note: Make sure you use fabric glue, I have found other glues go through the fabric, and leave hardened glue spots on the good side
Step 4, 5, and 6 picture:
Step 7: Test fit the rag top now, since the tubes are glued in, if there is no opening under the roof, enter on a slight diagonal, and straighten out, do this for each paperclip. Once you get it in place, roll it back and see how it looks
Step 8: After test fitting, remove the clothe carefully, being sure your not going to loosen or break the glue joints. Then apply putty to the seem where the tube meets the roof, and sand smooth. After that prime paint and apply to your build.
Here is a picture of it opened and closed
Give me some feedback, and if you have any questions, feel free to ask, hope this helps
Old 05-13-2005, 01:22 AM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Re: Tutorial: Making a Rag Top
Great tutorial, but if I have one comment it's that you should change the name of the tutorial. "Ragtop," at least to domestic car fans, is another word for "convertible," so I had assumed this was a convertible you were making until I saw it. I believe I've seen this roof referred to as "panoramic"... or heck, even "big sunroof"
Old 05-13-2005, 01:32 AM
O yea forgot about that. Im renaming it to roll back ragtop
Edit: It won't let me edit it, people will find out eventually, also thanks for the positive feedback
Old 05-13-2005, 02:42 AM
_WIDE_LOAD_'s Avatar
_WIDE_LOAD_ _WIDE_LOAD_ is offline
Send a message via MSN to _WIDE_LOAD_
Excellent tut dude....might have to try that this weekend on a scrap kit.
Later, WIDE
My name's Troy, use it if you like.
If you're a Buddist, you go to Tibet....If you're a speed freak you go to the Salt Flats
351 clevo....aussie muscle
Old 05-13-2005, 03:07 AM
klutz_100's Avatar
that's really cool!! Super tutorial, great thinking. Thanks
I'm working on a Cooper myself at the moment and was thinking "what can I do to it to make it different from all the others" and that's exactly what came to my mind too. The seperate roof part just begs for it.
Thanks for making my life easier )
stevenski
Old 05-13-2005, 07:29 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
I'll probably never have the need to use this tut, however, respect for posting it up! Looks good!!
Old 05-13-2005, 07:53 AM
tonioseven's Avatar
Re: Tutorial: Making a roll back ragtop
Title changed.
Old 05-13-2005, 08:39 AM
drnitrus's Avatar
drnitrus drnitrus is offline
Great Tutorial! I have a project Im doin the same type of roof.
Old 05-13-2005, 11:48 AM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
u read my mind, i was thinking of how to do this just last night for my vw camper, im planning on having a full length sun roof
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 05-13-2005, 01:42 PM
Re: Re: Tutorial: Making a roll back ragtop
Originally Posted by tonioseven
Title changed.
Thanks for changing that, and for all the positive feedback, i am working on another tutorial right now, going to have to wait and see
Old 05-14-2005, 02:13 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Ha, thats really cool. Great stuff Sidewayz
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 05-15-2005, 03:18 AM
blubaja's Avatar
blubaja blubaja is offline
This is great!! I was actually going to do this to a wrx kit:-/....I wouldn't otherwise, but there are extras. It's gonna suck I know. Great how to! Thank you.
Frank X.
