Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 05-13-2005, 12:03 AM
Honda Sonic Honda Sonic is offline
low revs in 5th gear
I have a Honda Sonic 125 4stroke (Thai motorcycle). As standard the top speed was 120kph. I have fitted a performane exhaust, carb, cdi unit and changed the sprockets (bigger front, smaller rear). These mods produced loads more revs (10,000) and a lot moe acceleration. However, in top gear the max speed remains the same at 120kph and the engine revs at 4000rpm. I have tried various jets sizes in the carb, as well as various sprocket combos. I can get 120kph in 4th gear, but when i cange into 5th there's no extra speed, in fact there's a tendancy for the bike to slow to 110kph. I have consulted a few mechanics here in Thailand, but the best answer i could get was "this is a common problem with this model, 5th gear isn't very good." Can anyone give me a better response than this?
Old 05-13-2005, 08:10 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: low revs in 5th gear
Given your change of sprokets, you should get the acceleration results you got, but you should not be able to reach the same top speed. When you compromise gearing like that, you compromise top speed. It is like a Catch-22 if you will.
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 05-13-2005, 04:33 PM
aussieidiot's Avatar
aussieidiot aussieidiot is offline
Gone crazy! Back soon
hang on.
am i wrong but with a larger front and smaller rear, acceleration would decrease and top speed increase.
any way the power of the bike may have trouble producing torque in 5th gear as it is only small capacity and not designed for top speed.
at that speed the motor is working to hard and is losing power through wind resistance, internal friction but the big one is unsprung weight.
its wasting alot of power just trying to keep the rear wheel/tyre spinning
Old 05-16-2005, 06:21 PM
NaKeDZX NaKeDZX is offline
Correct, the gearing change you made not only hurt accelleration, but top speed will not increase because your bike doesn't make enough power to pull the taller gearing. You hurt it all the way around.
Old 05-17-2005, 06:25 AM
speediva's Avatar
Okay, so I'm dumb and I didn't read the sprocket change carefully. I am hoping that the order was typed in reverse, upon more careful consideration.
Inform yourself:
AF User Guidelines
