Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 05-12-2005, 10:46 PM
Fayt99Cougar Fayt99Cougar is offline
Cleaning a IMRC
Can someone please tell me how to clean my IMRC. I have a race coming up soon and my car should be running faster. And also, could I put a 2000 mercury cougar superchip in my 99 cougar?
Old 05-13-2005, 04:52 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
i think your talking about cleaning the secondaries. The IMRC (Intake Manifold Runner Control) is actually an electrical unit controlled by the pcm that opens the secondary butterflies. However, because the secondaries open at 3750 rpm's, they due tend to gunk up with carbon. Its pretty simple. Just remove the 6 upper intake manifold bolts, and the intake manifold will pull up to expose the lower intake manifold which is what you want to clean. I think youll need an 8 mm socket for the lower intake manifold to remove. But once its off just take some carb cleaner and tooth brush and clean all the carbon gunk off of it. Its not hard at all.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
