Originally Posted by greyjeep
Now not only doe sit not run correctly, it does not even start. I have a feeling it is the starter ( or the engine seized) but have not a clue. All the lights stay onand when you try to crank it the only indication that anything is happening is that the radio dims, Does anyone have any suggestions?/ Thanks.
You can always turn the engine over manually with an 18mm socket on the crankshaft bolt to see if it seized or not. Some engines (don't know if Neons are subject to this) can have a worn starter jam it's teeth on the flywheel freezing up the starter and turning over the engine manually will pop it free. Before doing this, make sure that your timing belt hasn't broken or jumped or you will bend valves on the pistons!
What makes you think that the engine may have seized?
