Old 04-11-2002, 06:31 AM
Ssom's Avatar
Ssom Ssom is offline
Send a message via ICQ to Ssom Send a message via AIM to Ssom
Signs you are a rice boy
I got this e-mail today, I have simplified it and made it easier to read so try and bear with me
SIGNS THAT YOU ARE A RICER
-You have more exhaust decibels than your engine has horsepower.
-You have aftermarket FRONT wheels for racing but stock rear wheels.
-Your engine makes twice as much horsepower as torque.
-You ever painted your wheels to match the same color of your car.
-You put your automatic car in neutral at every stoplight in order to roll it back and try to fool other people into thinking you have a manual
-DuPont gave up trying to figure out the shade you were asking for.
-Your mod list includes stereo equipment, shifter handle, MOMO steering wheel, PIA driving lights, exhaust tip, but no REAL engine parts.
-A chameleon lizard undergoes fewer shade changes than your custom paint scheme.
-Your rims and tires are so large, that you have to install the tire/wheel from underneath the car because it simply won't fit in the wheel well going in from the side.
-The dealer laughs when you bring your car back in for service under warranty, and you've only had it 6 months...
-Your tires / rims stick out from the lip of your car by more than 1".
-Your paint job is from the WRONG end of the color spectrum.
-You installed spacers on your STOCK wheels and tires to get them to stick out past the fender.
-You see cars like yours in a Shriner's Parade for Children and clowns are driving them.
-You bring a empty Maxwell House coffee can with you to compare size when you shop for an aftermarket exhaust system.
-Your Eclipse GS-T hardtop has a "SPYDER" emblem on the rear...
-Your knowledge of suspension is: "the more negative camber, the better the handling."
-You push your through the staging lanes. That way, maybe you can break into the 16s by keeping the motor cool between runs.
-You add a super tall rear wing, and a hundred pounds of aftermarket ground effects, yet you gut the interior and yank out the rear seat for weight savings.
-Your rear wing AND your rear window have a third mount brake light...
-The back lighting in the gauges in your A-pillar gauge pod work long before the actual gauges are hooked up.
-You cut 4 coil springs and scrape the chassis on the ground. Sparks are cool when you corner at normal traffic speeds!
-You have to find a way to drive AROUND speed bumps in a parking lot.
-You install clear corner and brake lights to be different.
-You install colored bulbs in your clear lenses.
-You ever put neon on the bottom of your car, and then busted it on the first speed bump you went over.
-You painted the UNDERBODY of your car to match
-If your rear spoiler is taller then you are.
-if you can fit fist f**k your exhaust tip
You have more stereo WATTS than engine TORQUE!
-If your tailpipe extension is the most expensive mod you’ve done to your engine yet.
-Your tailpipe extension fell off during a quarter mile race and you went three tenths of a second faster due to weight savings.
-EVERY car in your class has a turbo pushing double digits worth of boost.
-You spent $5,000 on the engine and you can not out run a stock Camaro, Firebird, or Mustang GT
-You want the 'wastegate' sound, but don't want to install a turbocharger system.
-You think Nitrous Oxide on your Hyundai Sonata puts you in the same performance league as the Chevy Corvette.
-The automatic version of your car runs 2 seconds slower in the 1/4mile.
-If the 1970 Plymouth Daytona Superbird has a smaller spoiler than your car does.
-You think the Del Sol is a sports car...
-A torque converter does NOTHING for your car.
-You think a deep farty noise = the sound of high performance
-If you think that horsepower is far more important than torque
-If you have ever claimed that switching to a cone filter has given you more than 10 HP.
-If you have ever considered installing more than one set of fog/driving lights.
-If you claim that the aftermarket cold air intake system you just installed doubled your horsepower or took 2 or more seconds off of your E/T.
-Your baseball cap is always on backwards when you drive.
-You spent all night on the Internet trying to find a company that makes a turbocharger system for your Hyundai...
-If you removed your side view mirrors and put them at the TOP of the door / window frame.
-If you think the Fugees are 'speed' music.
-MOMO is 'absolutely required' to go fast.
-Your four cylinder has a dual exhaust system installed.
-Your four cylinder has four exhaust pipes ("Hey, one for each cylinder!")
-The color of your interior upholstery hurts the cones and rods in other people's eyes.
-If you cannot drive your car in snow as the ground effects create a plow effect.
-If you have installed driving lights to compensate for headlight blackouts / tape.
-If you think that 280 horsepower and 185 lb/ft of torque are impressive for a ‘mildly’ modified engine.
-If you have stickers on your car for parts that you could not point out if asked where those parts are installed.
-You think pushrods are a bad thing…
-Your car has more decals than you do the quarter in seconds.
-Every Honda you EVER owned, all the way back to your 1978 Accord was either a V-Tech or a TYPE-R.
-You took your rear seat out and gutted your interior for weight savings but you installed 400 pounds of electronics, neon, DVD, Sony, etc.
If you gutted the interior to save weight on a car that you will never take to the track…
-You lean your seat so far back when you are driving, that everytime you hit a bump, its your back and not your butt that hurts.
-You have hydraulics and sixteen switches on a car you claim runs low 10s on the street and corners better than a Porsche.
-If you can estimate that your car makes more than 250 HP without ever running it at the track or getting a dyno reading.
-You claim that you can get a titanium block for your engine.
-If you have ever thought Hyundai and "PERFORMANCE" went hand in hand
-If you've ever gone to a parts shop or speed warehouse and asked for a 1" to 6" exhaust adapter...
-If you've ever contemplated adding "TYPE-R" stickers to your Sonata…
-If you've removed more than 1/2 of the coils from your springs by cutting them yourself ...
-If you have more neon lights on your car then a strip club...
-You put Kanji on your Ford ZX2 or Ford Probe...
-You own a "TYPE-R" Hyundai or Mazda.
-You couldn't afford headlight masking, so you just painted them with flat black Krylon and its peeling.
-You claim that polishing your intake gave you 5hp.
-You own a V-TECH Hyundai or Mazda (especially a V-TECH ROTORY Mazda RX-7)
-You have neon INSIDE your car or in your ENGINE compartment
-You ever claimed that high gas mileage made your car superior in performance to V8s.
-If it takes you 8000rpm to reach 30mph from a dead stop at WOT.
-You think yellow plastic interior trim makes your car cool
-You spend $500 for a giant hand welded tube for a muffler with the weld marks extremely visible
-If you paint your drum brakes to simulate Hi-po calipers
-If you install fake hi-po caliper / disc simulators
-You have a FRONT wing.
-If you lower your car and add ground effects but retain the stock 14inch wheels with disc style wheel covers
-If you equate the sound of performance with the sound of a Weed Eater™
-If you think bolting a fake muffler to one side to simulate dual exhaust is cool
-If you think colored head lights work better
-Clear tail lights and turn signals. They’re colored for a REASON!
-If you take mom's 4 door Honda accord and do any kind of mod to it
-You drive a Ford Escort station wagon with Kanji, wide tires, and Limp Bizkit stickers on the rear hatch
-You claim you lost the race because you had a passenger in the car.
-You claim how if you went from a roll you would have beat him.
-You claim you lost because you missed a shift.. and your car is an automatic.
-You claim you lost because he must have been on the juice..
-Flying past the person who is 10 car lengths in front of you after they have put on their brakes.. and claim a victory.
-after losing you flip your opponent off.. rev your motor and fail to break the wheels loose even around a corner.
-Tell everyone about how you lost the cop because of your "driving skills".
-you are a white kid driving an import.. wear baggy pants/hat turned around, walk with a fake limp and end every sentence with "yew know wha I'm sayin?"
-Your idea of aiming a handgun is raising your arm over your head, pointing the gun away from you, and then just letting your wrist fall to the side to where the gun is almost sideway ...
-drive around in a $20,000 import with $10,000 in mods.. and still live with your parents.
-You can relate to every line of the song "Pretty Fly For A White Guy" by the Offspring
-you take offense when I say.. "your sister is like your car.. small, tight and relatively easy to get into."
Old 04-11-2002, 07:37 AM
primera man's Avatar
"P-Man"
They would have to be the best i've heard
View All My Models Here.
Old 04-11-2002, 12:29 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Yes. Thats pretty good
Resistance Is Futile (If < 1ohm)
Old 04-11-2002, 04:10 PM
Spec2 Girl's Avatar
Spec2 Girl Spec2 Girl is offline
Send a message via ICQ to Spec2 Girl Send a message via AIM to Spec2 Girl
Very funny and I’m proud to say that there’s no rice on this baby!
My latest ride!
1998 Nissan Skyline R34 GT-t
Old 04-11-2002, 08:14 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
That was cute!
I have decided that if Asian imports are called "rice" then Domestics with such mods are to be called "pork" and German imports are to be called "wienerschnitzel"
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 04-11-2002, 08:16 PM
Spec2 Girl's Avatar
Originally posted by saturntangerine
That was cute!
We call domestics over here spud (Italian cars are Pasta, etc, etc) basically the whole complex carb spectrum.
My latest ride!
Old 04-11-2002, 09:25 PM
Ssom's Avatar
When you say domestic do you mean Chey Camaro Z28 (US-made), Holden Torana V8 (Aus made) or a 2.0l Ford Telstar (NZ-made)???
Old 04-11-2002, 09:28 PM
Spec2 Girl's Avatar
Mainly just the Fords and Holdens.
My latest ride!
Old 04-11-2002, 11:11 PM
speediva's Avatar
In my case, it would mean any nasty-ass Chevy Cavalier (like this one that is modeled after the green Eclipse from you-know-which-movie) or icky Ford Focus that's all goofy looking. It would be anything "American Made".
Inform yourself:
AF User Guidelines
Old 04-12-2002, 05:22 AM
Ssom's Avatar
A ricey domestic to Kiwi's is a Ford Telstar or Nissan Sentras that have been fucked with by rice-boys
Old 04-12-2002, 02:08 PM
banchi105 banchi105 is offline
Banned
Send a message via AIM to banchi105 Send a message via Yahoo to banchi105
OMG! Those are so freaking hilarious & TRUE!
Old 04-12-2002, 02:51 PM
Darkwing Darkwing is offline
I agree with all of those except I have a question on this one:
You talking about RMS, peak, total, or what?
I have a 180 total watt system with 130 hp. It is 23 watt rms x 4 and 45 watt peak x 4
that make me a ricer?
Anyways, pretty funny list. Especially the one about flying past the guy who put on his brakes!! Its so true!! I never done it, but...
Check out my webpage at www.darkwing72211.com. It's got a new page specifically for my Car!
Old 04-12-2002, 05:56 PM
Porsche's Avatar
Porsche Porsche is offline
Pretty much amazing
Send a message via MSN to Porsche
I'm not saying anything but your sig... welll...
ec437 on grammar;
Originally Posted by ec437
I'd've
Originally Posted by 2strokebloke
Any car built by "Dr. Technology" is probably not worth $5000
Old 04-12-2002, 08:36 PM
hdtboy hdtboy is offline
Send a message via AIM to hdtboy Send a message via MSN to hdtboy
am i a ricer?
i have 1000wrms in the boot, i wish i had 1000Nm under the bonnet
Old 04-12-2002, 10:13 PM
lol, its an old one, I guess I need to change it
