Old 05-12-2005, 08:59 PM
97GreenGTP 97GreenGTP is offline
Belt question
I am planning to change the belts. Autozone has Gatorback in 2 different lengths. One is 93-1/2" for 17.99 and other one is 93" for 23.99.
Does anybody here know which one is for 97 GTP with 106,000 miles
Old 05-12-2005, 09:32 PM
shingle_man shingle_man is offline
Question
Which belt are you planning on replacing? There are two belts to choose from - Accessory or Supercharger. Let us know.
Old 05-12-2005, 09:44 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Belt question
This is the one I use on my supercharger
http://www.pfyc.com/store/merchant.m...y_Code=GPUNDER
Old 05-12-2005, 10:45 PM
I am planing to change both. I am confused about the accesory belt as it is offered in 2 lengths at Autozone.
Gatorback Part # 4060935 93 1/2" BELT $17.99
Gatorback Part # 4060930 93" BELT $ 23.99
Please advice me on this.
Thanks
Old 05-13-2005, 12:31 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Belt question
Thanks
On my '97 GTP I recall undergoing a similar problem but that was over 5 years ago so my memory is vague. There were two serpentine drive belt designs for that year. The 93" was AC Delco part number 6K930. The 93 1/2" was AC Delco part number 6K935. If the numbers are still visible on the old belt if OEM maybe you can cross-reference the number to the proper size Gatorback. Mine was the 93 1/2" #4060935 Gatorback probably because the car was a '97.5 model.
Timeslip 08/12/06
AF Community Guidelines
Old 05-16-2005, 11:37 PM
shatter65 shatter65 is offline
Re: Belt question
i just bought a new belt for my 97 from autozone 2 days ago and i just went for the longer one because there is only a 1/2 inch difference between the two and i figued if i got the longer one then the tensioner would pick up the slack...better to go longer than shorter if you are in doubt..at least it worked out for me in this case
