Old 05-12-2005, 05:35 PM
flirtypurty flirtypurty is offline
noise when turning right FIX
the rear transaxle mount is the cause for the growling sound.This is located inside the driverside wheelwell.Turn your wheel all the way to the left & you can see it.Use jack & put pressure on the trans,loosen the two nuts (do not remove).Lower the jack just a little,center the two studs in the rubber mount w/your finger(push them towards the engine compartment).Jack the trans back up & tighten nuts to 33 ft lbs.I found this was a service bulletin in 1998. Them studs/nuts need to be moved towards the engine compartment around 1/8 "or so.
