Old 05-12-2005, 05:35 PM
funny funny is offline
Banned
help need!!!
Hello!
I need your help:I want to build the Chain for the HONDA 211 RC-V.
how can i make the sticks(1mm and 1,2 mm) in the right dimension?
Thanks all,Funny
Old 05-12-2005, 05:54 PM
RallyRaider's Avatar
Zomby Woof
Re: help need!!!
Is that brass rod? Tricky stuff to cut. I use a cutting disk in a rotary dremmel style tool. Heats everything up and is not that clean (or safe!) but does the trick quickly. I imagine it will take a long, long time to link up all those pieces no matter how you do it. Maybe substituting some plastic rod of the correct diameter will make the task easier?
Old 05-12-2005, 08:31 PM
A_C A_C is offline
This modeler gave some tips on building this chain...
http://www.asahi-net.or.jp/~xr2h-fkd...lton/index.htm (Progress->page 4)
Hope it helps.
Old 05-12-2005, 09:47 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: help need!!!
I've had success cutting smaller, harder wire in a miter box, with a sharp razor saw. Much more accurate IMP than a tubing cutter.
Or, and experiment with this one, take a small pair of wire-cutting pliers, and fill the 'back side' of the cutting area (When closed) with silicone. Let it cure, and then slice it down the middle to you can open up the pliers. Then, find a place on the pliers where the depth is right, and simply snip away. The silicone should catch the pieces, but maybe do it in a plastic bag or something, just to be safe.
Old 05-12-2005, 09:58 PM
Re: help need!!!
After reading that guy's website, do it his way: Drill holes the right depth is some plastic and use side cutters for it (Get a cheap pair of flush-cutters at Radio Shack, $4, who cares if they are dulled by the end). My ways will work, but are more complicated.
I prefer to think of it as a complex solution comes from a complex mind, a simple solution.......
Old 05-12-2005, 10:04 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: help need!!!
i cut my brass rod with a good pair of scissors
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 05-13-2005, 12:57 AM
joelwideqvist joelwideqvist is offline
Re: help need!!!
I haven't tried this chain set myself, but what I've heard the easiest way is to mount the chain links on the rod and then cut it. Shall be terribly tricky but the end result, if successful, is great.
/Joel
Old 05-13-2005, 04:59 PM
Banned
Hello!
Thank you for the Answeres.The link from the Cycle is very interesting to build the Chain.It helps very much.
Thanks all
Funny
