Old 05-12-2005, 02:52 PM
civicroundabout civicroundabout is offline
ball joint woes
ok the lower ball joint was a pain to get out, but i finally got it out. in the process the threads on the ball joint stud are all messed up and i cant get the castle nut back on it. how do i fix the threads? also, its only the last 3 or 4 threads, around the hole for the cotter pin. can i just file off the messed up threads since there really not used? help asap please
Old 05-12-2005, 03:24 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: ball joint woes
You can rethread it or you can try what you said. When replacing my upper ball joints, I actually misplaced one of the new cotter pins (old were fucked) so I customized a thicker cotter pin to fit.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
bum
Old 05-12-2005, 07:14 PM
BullShifter's Avatar
Re: ball joint woes
You can run a thread chaser on it or just replace it.
Old 05-14-2005, 04:11 PM
CR50HC CR50HC is offline
Re: ball joint woes
I'd relplace it if you could. Better to have a good original part than something that was band-aided.
Old 05-14-2005, 05:10 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: ball joint woes
expecially on a ball joint!
Old 05-15-2005, 12:39 AM
Re: Re: Re: ball joint woes
There is nothing wrong with re-threading a ball joint.
