Old 05-12-2005, 01:17 PM
19prixgt98 19prixgt98 is offline
Banned
foglight replacing
how do you replace the foglight bulbs on a 1998 grand prix gt? How do the housings come out to get to the bulb?
Old 05-12-2005, 03:32 PM
ericvrose ericvrose is offline
Just raise the car a bit and look under there. The socket is a twist off and the bulb plugs in. Housing doesnt need to come out.
Old 05-12-2005, 04:20 PM
cjgrandprix's Avatar
cjgrandprix cjgrandprix is offline
Cool Re: foglight replacing
Look in back of the light(under the car). On mine there are two nuts(10mm) that have to be taken off to take the foglight housing out, which allows you to easily replace the bulb.
Cheers,
CJ
Old 05-12-2005, 06:15 PM
Banned
thanks guys!
Old 05-13-2005, 01:42 AM
stlwagon stlwagon is offline
Agree with Eric... Don't remove the housing. Just twist the bulb socket carefully. It may take a little force due to road grit but it will come out. Also, when replacing the bulb be sure not to touch the glass with your fingers. Oils in your skin will shorten the bulb life.
Old 05-13-2005, 01:47 PM
Another tip when putting it back in. Look through the front of the lens while your trying to turn the socket back in. It makes it alot easier to align the tabs with the notches.
Old 05-13-2005, 10:58 PM
Banned
wow good advice guys, thanks a million! will remember that when i go to change them!
