92 Accord Oil Leak Valve or Gaseket
Hey all. I have a 92 accord that was stolen and I just recovered it (after 4 months). I notice now that there is a substantial, i mean a lot of oil leaking in the engine after a 5 minute drive. I have been reading up on the forums and what was indicated is to replace the 'VALVE COVER GASKET', or the 'HEAD GASKET'. For some reason, I thought they were both the same, but I guess not.
Can someone please tell me what is the difference, where they are located, and from the picture attached, where the oil is coming from? I pretty much know that I have to look for a guide to replace it, but if anyone wants to tell me what needs to be replaced, that will be appreciated also. Sorry for the crappy picture. The RED indicates places where I see oil. Also, if you can point me to the right items on www.autozone.com, that would be so fantastic. Thanks All, Scott
Re: 92 Accord Oil Leak Valve or Gaseket
Show us the picture!!!
Valve cover gasket and head gasket are totally different. The former can be replaced in 20 minutes. The latter needs at least 6 hours. |
Re: Re: 92 Accord Oil Leak Valve or Gaseket
Thanks Proman.
The picture is there though. YOu dont see it? If not, go to http://www.geocities.com/cscott784/Pics/OIL.jpg Can you tell me which is which and where do you think the oil is coming from? Thanks, scott |
can anyone help me?
Thanks, Scott |
You need a valve cover gasket. That's the "pan" on the top of the motor, where the oil is leaking. The head is the top engine casting below that cover, the head gasket is at the seam between it and the engine block.
You can change that VC gasket easy.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
This is not your engine, but for the purpose of identification of the parts we're talking about, it'll do. This is an old Jeep 4 banger.
1. Valve cover 2. VC gasket 37. Cylinder head 36. Head gasket #37 is identified as "Water Outlet Fitting" in the ID list, because this is a list of external parts. The cylinder head is not identified, but the water outlet is bolted to the head.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. Last edited by jeffcoslacker; 05-15-2005 at 05:30 AM. |
You could make sure the valve cover is properly torqued before replacing the gasket. It's worth a try. Damn, I don't know if I'd want a car back after stolen that long.
Thanks all for your help. I succesfully replaced the valve cover gasket and all is well. Thanks again.
Scott |
