Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 05-12-2005, 12:13 PM
drj95018 drj95018 is offline
What's Normal Compression for a 22R
I have recently acquired an 85 4X with a 22R motor. It's overheating and using water, although there is no oil in the water or vice versa. I hear head problems are common in this motor and (thankfully) got the truck cheap enough that I have no problem with pulling the head and having it rebuilt, but was wondering if it was worth it on an engine of unknown lower end health. I did a compression check (cold engine) and got 170-180 across the board. So the question is, are these compression readings Good or OK or Poor?
Thanks
DrJ
Old 05-13-2005, 12:12 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: What's Normal Compression for a 22R
1st - Check your oil pressure. If your lower end has good clearances, then your oil pressure will be normal. Minimum of 4.3 psi at idle and 36-71 psi at 3000 rpm.
Compression should be around 170 psi, minimum of 130 psi. They should all be fairly even at any reading above 130 psi. 170-180 looks good for compression. Might actually be a little high - indicating excessive combustion chamber deposits. Run some SeaFoam or GM Top Engine Cleaner through the engine via the intake.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-13-2005, 01:48 AM
KimMG KimMG is offline
AF - Advisor
Pressure test the cooling system to check for small leaks. Also pressure test the radiator cap.
Old 05-13-2005, 11:18 AM
Brian R.'s Avatar
Resident Chemist
Re: Re: What's Normal Compression for a 22R
This is definitely the way to go before you replace the head gasket. Your leak could be anywhere. Head gasket is the last thing to replace to fix a coolant leak.
Old 05-13-2005, 11:32 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
I have read alot about the coolant escaping out the exhaust valve on the #4 cylinder. Apparently the coolant, if improperly mixed, will eat away at the aluminum block??? It's worth checking out. Good luck.
WAR UTAH!!
Old 05-14-2005, 12:38 AM
Brian R.'s Avatar
Resident Chemist
That is truly bizarre. It's supposed to protect the head, not react with it. Maybe it just leaks there through a crack in the seat or something else from an unrelated cause.
Old 05-14-2005, 09:55 AM
Yeah, I thought that was bizarre, and it may just be "talk"! It is hard to say. I have come across it several times, both in this forum and "others"!
http://www.automotiveforums.com/vbul...t=coolant+leak
It looks like the #3 valve, not the #4. Ferrrous block w/aluminum head.
WAR UTAH!!
Old 05-14-2005, 07:57 PM
Brian R.'s Avatar
Resident Chemist
OK, I see. He reports that this problem occurs when you run water or very dilute antifreeze in the engine. That I can believe. The antifreeze doesn't kill it, it just doesn't protect it because it is too dilute or non-existant.
