Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-12-2005, 10:49 AM
MR2turbo93's Avatar
MR2turbo93 MR2turbo93 is offline
Stock Fuel System
If i was to run a CT20B at 17psi with a spearco intercooler, TKO DP and 3" exhaust with a K&N filter of course, is the stock fuel system still sufficent or should i upgrade?
If so what do i need to do? do i need to do the whole system?
Thanks
"In Reality we have this thing called physics. Respect it, or it will kick your ass."~ Dave Coleman
Old 05-12-2005, 01:07 PM
SHORTYBOY113 SHORTYBOY113 is offline
Re: Stock Fuel System
you can run more than 17 psi with a spearco i/c and a ct20b. i dont no if u have to upgrade the fuel or not. i would amagine so. if so i would go with 550cc injectors with a supra fuel pump and fuel presure regulater and go and get it dyno tuned for best results.
CARDOMAIN.COM/ID/MR2_SEXY11[color=red]I DONT NO HOW TO ADD IN A PIC SOMEONE TELL ME.[IMG]car pix 009[/IMG]
Old 05-12-2005, 03:48 PM
mr2envy mr2envy is offline
Send a message via Yahoo to mr2envy
depends on how much power your making if your over 300hp then everywere says you need to upgrade and a popular one is just drilling it out to 450cc injectors. but we you chose works
-=Prospect Motorsports=-
Old 05-13-2005, 11:19 AM
MR2turbo93's Avatar
well if i was to do it i'd get supra injectors, ats ported fuel rail, and a walbro 255lb/hr pump and a aeromotive fuel press. regulator but i reall dont want more than 300whp and i dont want to have to buy a programmable ECU cause no one around me knows how to tune it, does anyone know of a good tuner in the NY,NJ, Penn. area ?
Old 05-17-2005, 07:21 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
I suspect the OEM fuel would be sufficient for 17 psi out of a CT20B.
You may want to just do an adjustable FPR to bump up your fuel pressure:
www.trueleo.com/fpr.htm
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 05-18-2005, 05:03 PM
wow thats pretty cool. he hyde do you have anything done to your internals? like cams roged pistons bore port and polish anything?
Old 05-18-2005, 07:16 PM
AF - Advisor
My was 100% stock and unopened until 2-3 months ago ... we pulled the valve cover off and dropped in cams.
We changed notihng else ~ I am still using the original valves, springs, etc ...
Old 05-18-2005, 07:17 PM
wow thats awsome whats the max psi and hp and tq youve had on it? before cams
Old 05-19-2005, 04:51 AM
AF - Advisor
351 rwhp and 300 rwtq
