Old 05-12-2005, 04:35 AM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Interior black--best choice?
I'm finding it difficult to make a happy medium when it comes to making leather or vinyl interiors. Gloss black simply looks too shiny, and flat black looks too flat. I believe I've even tried semi-gloss a few times with mixed results. Does anyone have any little tricks to make the vinyl or leather interiors look realistic?
Old 05-12-2005, 06:20 AM
hawkone hawkone is offline
Send a message via AIM to hawkone
Re: Interior black--best choice?
hi tigeraid you could mix the flat with the semi gloss until you get the shineness you require or what i do is use tamiya flat black and when dry rub it gently with my finger and it will leave some grease from your skin on it which gives it a slight shine looks good. good for leather or vinyl look dont have to be flat black just use any flat colour you want and rub with your finger. hope this helps.
Old 05-12-2005, 06:27 AM
generationx's Avatar
generationx generationx is offline
Another method I tried in the past was to use matt black, then get a sharpened candle and rub the tip over the paint surface. Gave it a polished leather look.
Old 05-12-2005, 06:31 AM
tonioseven's Avatar
I take a bit of grease from the outside of my nose and rub it into some matt or semigloss blask. Seriously!
Old 05-12-2005, 06:57 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
What about automotive vinyl dye?
Old 05-12-2005, 08:26 AM
gasman03's Avatar
gasman03 gasman03 is offline
Krylon Seme-Flat back, available almost anywhere that sells paints. (Wal-Mart, JoHann Crafts.......) gives the most realistic looking leatherery, interior black out there, it also works great for chassis's
Old 05-12-2005, 08:54 AM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
Re: Re: Interior black--best choice?
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 05-12-2005, 09:30 AM
SchuberT's Avatar
SchuberT SchuberT is offline
Floquil makes a black called Engine black that is very versitile. It's not quite semi-gloss, and not quite flat, and you can vary the finish by how thick you put it on. Best of all is that it's almost self-leveling. I've brushed this stuff on and come out with results just as good as if I sprayed it through the airbrush. It's truly great.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 05-12-2005, 03:59 PM
tigeraid's Avatar
Authorized Vendor
I like the candle idea tho, I'll give it a shot. Thanks!
Old 05-12-2005, 04:12 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
satin black is good, and the rub on Graphite dust. this gives a bit of other color and makes it look good.
Old 05-12-2005, 05:31 PM
RallyRaider's Avatar
Zomby Woof
I'm with Tonio. Flat black with a little skin oil rubbed in gives a very nice leather luster effect.
