Old 05-12-2005, 12:29 AM
2001ss 2001ss is offline
Thumbs up MAF Sensor
Hello
I just installed an SLP MAF, i havent tested it out yet, but what do you camaro lovers think this will do to the performance of my vehicle
any sugestion on what to do next, since i decided not to install headers.
[IMG][/IMG]
[img]
Old 05-12-2005, 08:43 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: MAF Sensor
Originally Posted by 2001ss
any sugestion on what to do next, .
1 - sell me your car,
j/k nice ride
Old 05-12-2005, 09:31 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: MAF Sensor
It will probably lose you 2-3 HP.
If you can, send that back. They aren't worth the money unless you tune for it. On top of that, you don't need it until you are making so serious horsepower numbers. Like over 500.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 05-12-2005, 10:12 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: MAF Sensor
agreed, us turbo buick guys use LS1 MAFs up to 550 horse with no problems.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 05-12-2005, 06:58 PM
Re: MAF Sensor
i did not know my car was going to lose that, i belive i can not return without a 15% lost.
i have a problem my car keeps on heating up, i think it is the sensor, but who knows, that is why i have a manual fan and a 160 thermostat, and i thought putting the MAF will help.
any advise, i think it heats up because it sometimes the temp passes 210 it probably goes up to 230
[IMG][/IMG]
[img]
Old 05-12-2005, 09:44 PM
Mr. Luos's Avatar
Firebird Guy
Re: MAF Sensor
Flush the coolant?
Stock'ish'
Old 05-12-2005, 09:52 PM
Re: MAF Sensor
i have done that when i installed the thermostat, and it was heating up before, and after
[IMG][/IMG]
[img]
Old 05-12-2005, 11:11 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: MAF Sensor
wow that sucks... dont know what to tel ya.....wait did you flush the colant part of the engine too. it gets water everywhere but it might help. it you take the hose that sends the coolant into the engine off and stick the hose in it turn it on full blast (oh and the other hose so the water will pour out of the engine and not go into your radiator) and start your engine and that should fush anything out of the engine if theres somtheing in there. let it run for a while and watch the temp gage!!!! make sure you dont over heat cause it will happen kinda quick with water going throught it...well it did for me but it didnt get too hot but it was hot. and i guess while your hoses are off flush the radiator again just to be sure. goodluck
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 05-13-2005, 12:55 AM
Morley Morley is offline
Re: Re: MAF Sensor
Fans are programmed to come on at 224* F...you aren't over heating unless the fans don't come on and the temp keeps rising.
Oh, and a MAF sensor won't cause a car to over heat without throwing a code..and then the car would be running like total crap..so you'd know you had a real problem.
Old 05-13-2005, 08:24 AM
wrightz28's Avatar
Re: Re: Re: MAF Sensor
Morley's on the money again, Gm likes running these puppies hot for emissions. Ballparked avg. run temp s/b 205-220 on most 3rd & 4th gens. And in traffic it will have a tendancy to be higher. Sounds like your ok so long as it dosen't get worse.
Old 05-13-2005, 09:21 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: MAF Sensor
If you are concerned about it running too hot put in a manual fan switch, that way when you are stuck in traffic you can flip it on when it looks like you're gonna be going slow for a while. Hell they even make switches that are both manual and automatic built into one so you don't have to worry about forgetting to turn it on.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
