Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 05-11-2005, 09:37 PM
kdawg5 kdawg5 is offline
Turn ignition and doesn't click-won't start
Car has a new battery (4 mos old), gauge lights, headlights, car buzzer, and you can hear fuel pump running when you turn ignition, but car won't start......doesn't even click. battery checked and has full charge. It is a 5 speed manual transmission, 1997 2 door Pontiac Sunfire. Could it be the ignition?
Old 05-12-2005, 02:40 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: Turn ignition and doesn't click-won't start
could be the clutch position switch as well as the ignition. if it cans "see" the clutch in, it wont even try to start.
Old 05-12-2005, 10:08 PM
Not sure if I know what you mean by "sees" clutch in
Old 05-13-2005, 01:27 AM
hotbug1776's Avatar
there is a clutch position switch that lets the starter turn over, a safety switch to prevent the car from being started while the transmission is engaged. it may have gone bad.
Old 05-18-2005, 04:12 PM
SunfireGT99 SunfireGT99 is offline
Re: Re: Turn ignition and doesn't click-won't start
A good way to test both is push start it, if it starts then that would mean nothing wrong with motor or clutch sensor and verywell might be your ignition now if it don't start then it could be sensor,ignition or motor have to go through and find what it is!
Old 05-26-2005, 01:40 PM
clarky99_69 clarky99_69 is offline
it could also also be the starter, the solenoid could have gone bad, i have a 96 and i just replaced the starter cause the solenoid went bad, the clutch switch is an easy problem to fix, by pass it
Old 05-27-2005, 01:11 AM
Re: Re: Re: Turn ignition and doesn't click-won't start
Originally Posted by SunfireGT99
A good way to test both is push start it, if it starts then that would mean nothing wrong with motor or clutch sensor and verywell might be !
not true clutch sensor has nothin to do with bum startin the car
