Old 05-11-2005, 09:17 PM
bonnie6095 bonnie6095 is offline
Cigarette lighter don't work
The cigarette lighter doesn't work, we have replaced the fuse and still doesn't work. Any other suggestions will be helpful
Thanks
Old 05-11-2005, 10:35 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Cigarette lighter don't work
If you can, pull the plastic shroud around the cigarette lighter and make sure it's plugged in and that the terminals aren't backwards.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 06-11-2005, 10:07 PM
Re: Re: Cigarette lighter don't work
The cigarette lighter had worked, I got the van new, and it quit working. That is why we had replaced the fuse.
Any other suggestions?
Thanks
Bonnie
Old 06-12-2005, 01:25 PM
tri-power's Avatar
tri-power tri-power is offline
Try plugging in some accessory to make sure you are getting power into it. If the accessory works, you may just need a new lighter element. If not you have a wiring problem. Maybe just a bad ground or a wire pulled off the lighter chassis.
Old 07-02-2005, 09:53 AM
I guess I'll have to take it in since accessory items are not working on either location, the front or the rear.
thanks for your help
Old 07-02-2005, 11:23 AM
B33p3r B33p3r is offline
There is an accessory relay for the cigarette and accessory outlets. Get the owners manual out and check it out.
Old 08-12-2005, 02:25 AM
a.karrick a.karrick is offline
my van didnt come with a cigarette lighter!
lol, it has an ashtray with a no smoking sign in it. lmao
