Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-11-2005, 09:12 PM
0262ecg 0262ecg is offline
Question not sure where to start
ok lets see 94 bonnie has 98212 miles on it 3800 ok changed alt afte about 2wks alt was no good ok tonight i changed it car does not charg as it should Battery is at 13 but gauge is in just on the line rready to enter red car will run but then all of a sudden car doesnt stalh but acts like it has have to pull ove rhard no power steering with this also put in park and turn off and pray it starts any ideas alos noticed when i use turn signal guage fluctuates
Old 05-11-2005, 10:06 PM
michael_k0's Avatar
michael_k0 michael_k0 is offline
Send a message via Yahoo to michael_k0
Re: not sure where to start
Try cleaning/replacing your battery terminals, sounds like a bad connection.
Old 05-12-2005, 06:56 AM
ok the terminal are clean and like i said if i use the turn signals it will fluctuate when i turn on lights and heat and trun signal guage drops almost into the red. I need this car only one i have and now the oil guage does not work wehn car is on it stays at 120 never moves has oil and the washer fluid ligh tis on has fluid (in the system monitor) the check guages light is on (ibelieve due to oil guage). This car has been a jinx from the beging and i hate it. I know the rear turn signal had water in it and the bulb was rusted in it had to dig it out. Well hope this info helps sorry I didnt post it lastnight.
Old 05-12-2005, 10:27 PM
10sec.et 10sec.et is offline
have you had your battery load tested? a battery with a shorted plate can cause a lot of weird problems. even if it is new load test it anyway.
Old 05-13-2005, 04:44 AM
markwb's Avatar
markwb markwb is offline
That definitely is still a problem. You're introducing a ground condition to the electrical system every time you use the turn signals. But the other problem is still the main focus. If you can, look at the under hood fuse center (maxi-fuse center I believe) and try to see if you can inspect the main power connections & buses underneath the fuse center. You are looking for loose connections there.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 05-13-2005, 05:55 AM
thomd53 thomd53 is offline
Send a message via Yahoo to thomd53
Just a suggestion.....make sure your battery cable connection at the solenoid (on the starter) is tight.....it sounds suspect
Old 05-21-2005, 01:54 PM
byrdland2003's Avatar
byrdland2003 byrdland2003 is offline
Also, check that your serpentine belt is not out of tolerence. This would cause a low charging condition.
Old 05-29-2005, 10:35 PM
montecarlossfan montecarlossfan is offline
check the fusible links that are inline...those tend to cause a ton of problems if it just doesnt charge
