Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-11-2005, 08:07 PM
apostrophe28 apostrophe28 is offline
Send a message via AIM to apostrophe28
idel question.....
just a quick question, i was just out in my z32 tt and i noticed that the idel is very very low.....i found when sittin at a stop sign it would drop down to about 300rpm and idel till i started moving again, is this a normal idel rpm? what do your cars idel at........oh it has the jwt ecu and boost jets...wondering if that might affect the idel....
Old 05-11-2005, 10:58 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: idel question.....
the ECU upgrade and boost jets should not effect idle...
probably a sensor problem...run an ECU diagnostics. i doubt anythign will come up being the check engine light isnt on but its worth a try.
now go through and wiggle your TPS sensor harness. that sensor is a common problem with these cars...
i have a couple mroe ideas for you 2 but you should start witht he most common. for now, if it is doing this constantly, then you can adjust the Idle Adjustment Screw to bump the idle up a bit.
and Idle is supposed to be around 700rpms in neutral.
ZedEx Crew Member #4
Old 05-12-2005, 01:56 PM
Bdetore Bdetore is offline
I'm a bit surprised to hear that the engine will stay running at 300 rpm. I would expect it to sputter and die around 500.
Old 05-12-2005, 03:17 PM
Zgringo Zgringo is offline
If you adjusting the idle adjustment screw you'll nothing but mask the problem. Find the problem and fix it. Check all the vacuum and air lines.
Old 05-12-2005, 03:27 PM
Z Cars Fanatic
yeah, but like i said... for right now you can adjust the screw to bump it up a bit...like if you need to get to a shop or the dealership or something of that nature.
Old 05-12-2005, 10:08 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
yah it would work to keep the car running until getting it fixed temporarily liek gringo said its not good cause all ur doing is masking teh real probelm and making it go away and then you can have more serious problems later on down the road when you would least likely need the trouble..
running ecu codes would be a good idea it will give u a good place to start if it throws some codes if none are thrown look at sensors like TOS,MAF,AACV jus a couple off the top of my head who knows u might also have a vacuum leak look for lines and hoses disconnected and look everywhere not jus skim on top of the engine cause they are hidden you can hear them sometimes so if ya can try ta listen for a hissing noise which will indicate tah vacuum leak ...
good luck on that...
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 05-13-2005, 09:39 AM
Hodo Hodo is offline
check to see if you connected your ECU up right, Make sure the none of the wires got pushed out of the connector, and see if any of them got damaged.
Start with the last thing you screwed with its probly that. Thats what I do when I have a problem at work.
Finaly got pics of my car....... after I washed it of course.
Old 05-13-2005, 10:40 PM
yah and usually tyhe problem is teh easiest shyt in twh world that you wouldnt be looking for dont try to stat with the complicated shyt first it will drive you crazy
Past Z Car Crew
Old 05-14-2005, 02:40 AM
MikeMan MikeMan is offline
Banned
Send a message via ICQ to MikeMan
Re: Re: idel question.....
The english language is pretty awesome yeah? Cmon man, for the sake of all of us, can you proof read your messages before you click 'submit reply'?
As for the idle problem, sounds like your AAC (Auxiliary Air Control). Does the A/C affect the idle speed? If not, then it could be a bung FICD (Fast Idle Control Device)
Does the idle problem happen when the car is warm or cold (or both)?
-Mike
Old 05-14-2005, 10:23 AM
Re: Re: Re: idel question.....
-Mike
You have to remember that Ex D had his arms ripped off in a combine accident back in the mid 1980's. He's been typing with his left big toe for almost twenty years while holding his coffee in his right foot. Give the poor guy a break. Pushing Delete that many time can cramp up a leg.
Old 05-14-2005, 08:38 PM
Banned
Re: Re: Re: Re: idel question.....
Haha, well if thats the case then I doubt he's an ExTrEmE DrIfTeR!!!!!!!!
Ahh yes, reminds me of when *I* was 12 and needed people to think I was cool. Those alternating caps really do it for me too.
-Mike
