Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 05-11-2005, 01:36 PM
gregfor1 gregfor1 is offline
ignition timing
can anyone tell me what the timing should be on a '93 golf 2.0 with an automatic trans and a/c. thanks
Old 05-13-2005, 02:52 PM
boschmann boschmann is offline
Re: ignition timing
The fine tuning of the ignition timing is performed by the ECM. If you pull the cap, rotor & dust shield you will see a small notch in the top of the distributor housing. With the engine set on TDC #1 the rotor should be centered over this notch, the ECM takes over from there. If they are not aligned you must reset the position of the timing belt. Note, the V notch on the flywheel is not TDC, it is the small O beside it that is TDC.
