Old 05-11-2005, 07:58 AM
Krickette Krickette is offline
Angry 1999 Grand am (SE) won't start!!! Security light!
OK, I've not much time to talk right now, will tell more later, but I'm gonna be late due to the fact that my CAR WON"T START! I have gas, checked the oil (eve though I can't get the *change oil* light to go off, I already changed it...Yeah, CAR WON'T Start!!! I bought it used, so I don't have a manual! HELP! I think I gave you all the stufff...it's blue, if that helps ^.^
Old 05-11-2005, 08:51 AM
Degtr Degtr is offline
Re: 1999 Grand am (SE) won't start!!! Security light!
Put your key in the ignition and turn it to the "ON" position (don't crank). Let it sit for 10 minutes. That should reset the Passlock security system and allow you to start it. If it keeps happening, you have a bad Passlock system.
Old 05-11-2005, 10:40 AM
evansdad evansdad is offline
Send a message via Yahoo to evansdad
i'm not disagreeing with you degtr but i was told it is 30 minutes, but i tried it on a 00 cavy and it didnt work. so good luck.
Old 05-12-2005, 04:16 PM
ddage01's Avatar
ddage01 ddage01 is offline
Degtr plan does work, i've done this twice in the past on a 97 Grand and it resets it fine. Of course if the module is gone.....
Old 05-12-2005, 04:22 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
welcome to the forum, krikette. Here's how you do the security relearn:
1) Attempt to start the car by turning the key to the Start/Run Position.
2) Observe that the vehicle fails to start and that the security light is illuminated.
3) Release key to the 'ON/Accessory' Position. (DO NOT turn key to the 'off' position.)
4) Allow the vehicle to sit with the key in the 'ON/Accessory' Position for no less than 11 minutes.
5) Turn key to off position and allow the vehicle to remain in the 'OFF' position for no less than 30 seconds.
6) Repeat #1 - #5 for 3 cycles.
On 4th attempt, car should start.
NOTE : Since this is a fairly long procedure, I would limit all electrical sources, such as disconnecting headlights, to prevent discharge of battery.
NOTE 2 : It is SAFE to wait LONGER than the allotted time, but it is not safe to wait less time. I.e. 12 minutes instead of 11 minutes should be safe; however, waiting 10 minutes instead of 11 minutes is not safe.
Properly executed, this procedure should take approximately 35 minutes to complete.
Good luck.
Old 05-22-2005, 08:08 PM
XtremeXP's Avatar
XtremeXP XtremeXP is offline
Re: Re: 1999 Grand am (SE) won't start!!! Security light!
Good luck.
I've had to do this several times except I just left the key in the on position until the security light stopped flashing (around 10 minutes) turned it to off and then It would crank right up.Dealership ende up replacing the ignition switch and it hasn't done it anymore. But I have started having fuel pump issues and just replaced the fuel pump today. I think the 2001 GrandAms are lemons and I'll NEVER own another!
Old 06-16-2006, 02:10 PM
GWENNETTE GWENNETTE is offline
Smile Re: 1999 Grand am (SE) won't start!!! Security light!
I have a 99 Grand Am If you turn the key to the on position without starting it and press the gas pedal three consecutive times the light will go off. (you have to press it completely to the floor each time)
Old 10-01-2010, 10:22 AM
frankshotrods frankshotrods is offline
Thumbs up Re: 1999 Grand am (SE) won't start!!! Security light!
Security light was flashing this morning! I got on the net and found info from a number of sites, including this one, about turning your key into the ignition to ACC, wait 10 minutes or so, till the light stops flashing. I went out about 7 minutes later, LIGHT WAS NOT FLASHING !! IT DID WORK! This time anyway.
